    Monthly Calendar
    43 Posts 24 Posters 59.3k Views 24 Watching
      pjkoeleman @nitram
      @nitram That is done depending on your country / language settings in the config.js file.
      For me I use language : ‘nl’, the calendar starts on Monday. When I use ‘us’ as language it starts on Sunday.
      N 1 Reply Last reply
      • N
        nitram @pjkoeleman
        @pjkoeleman Many thanks! and thanks for the speedy reply too. That set me on the right track - I am in the UK, so I thought the default setting of language: “en” would have been fine. Just in case anyone else ever gets stuck like I did, switching that to “en-GB” fixed it.
          palmaren
          Is it possible somehow to add week numbers to the monthly calendar? If so, how?
          P 1 Reply Last reply
            pjkoeleman @palmaren
            @palmaren The monthly Calendar has no option for week numbers. When you want that option ask the creator of the module.
            The default Clock module has the option showWeek, when set to ‘true’ is shows the actual week number under the clock.
              palmaren @pjkoeleman
              @pjkoeleman Thank you
                mirrX
                Is this module still working? I´ve set up a new system and the MM gives me an error and can´t start with this module. I have uploaded in the correct dir and also set up the config file correctly. But it won´t work.
                  pjkoeleman @mirrX
                  @mirrX said in Monthly Calendar:
                  Mine is, so have a look at your config and check for errors
                  • slametpsS
                    slametps
                    Mine is also with bug. It is not working well for new month. The calendar not showing nor highlight the 1st date. So, I must restart MM to make it works.
                    regards,
                    Slamet PS
                    J 1 Reply Last reply
                    • N
                      Novais
                      Having an issue displaying the calendar. Got the config set properly as far as i can tell just using the defaults and i have confirmed the config doesn’t contain any errors but the monthly calendar wont display, MM does start up with the other modules.
                        Jonae @slametps
                        @slametps i have the same issue, calendar not refreshing at month start. no fix jet?
                        BKeyportB 1 Reply Last reply
                        • BKeyportB
                          BKeyport Module Developer @Jonae
                          @jonae I had so many problems I wrote my own version. mmm-multimonth
                          J 2 Replies Last reply
                            Jonae @BKeyport
                            @bkeyport said in Monthly Calendar:
                            mmm-multimonth
                            thanks, i will try that.
                              Jonae @BKeyport
                              @bkeyport
                              Thanks for the tip, it is perfect, exactly what i need! i hope at the and of the month it will change :)
                              • BKeyportB
                                @jonae It’s been working perfectly for me for months. There’s been a couple of quirks, but I’m re-writing it from scratch to eliminate some underpinnings that are difficult. Please, let me know if it continues to work for you.
                                  Jonae @BKeyport
                                  @bkeyport It is working perfectly so far, I modified it to my liking, I love it, it should replace the calendar monthly by default! I hope you succeed with the rewriting of the code. Can you give me the official GitHub? I want to follow you for updates! Many thanks.
                                  • BKeyportB
                                    @jonae I’m not github’ing the partial product. once I adapt the concept from jsfiddle to magic mirror, I’ll establish a develop branch
                                      Jonae @BKeyport
                                      @bkeyport Great!
                                      • 2 / 3
