    Magic Mirror with AI
    64 Posts 14 Posters 75.1k Views 18 Watching
    • H Offline
      hayman
      very nice ,waiting for the code ,i’ve mini PC I3 can’t wait…
      akshaybahadur21A 1 Reply Last reply Reply Quote 0
      • akshaybahadur21A Offline
        akshaybahadur21 @hayman
        @hayman - great. Hoping that its worth your wait.
        • H Offline
          hayman @akshaybahadur21
          @akshaybahadur21 will you update us when you LL pissy the code?? Please
          akshaybahadur21A 2 Replies Last reply Reply Quote 0
            @hayman Yeah definitely. For more info check my github page
            https://github.com/akshaybahadur21/Smart_Mirror
            • F Offline
              fischi87 @akshaybahadur21
              @akshaybahadur21
              Good Morning, it is also Working dir german orr just english?
                akshaybahadur21 @fischi87
                @fischi87 hi…yes it works for German as well. You just have to train your model accordingly.
                • F Offline
                  @akshaybahadur21
                  very nice!!! how it works with the voice? i mean i need also a mic? is there a doc, how can i build this ai with hardware and so on?
                    @fischi87 yeah… you need to have a microphone… For detailed documentation see : https://github.com/akshaybahadur21/Smart_Mirror
                    • thommy86T Offline
                      thommy86
                      @akshaybahadur21 Any timeframe on when you will release the code. I am starting a new project, where I will use an old laptop. So this seems very interesting!
                        akshaybahadur21 @cowboysdude
                        @cowboysdude https://github.com/raghavpatnecha/smartmirror
                          @hayman https://github.com/raghavpatnecha/smartmirror
                            akshaybahadur21 @thommy86
                            @thommy86 https://github.com/raghavpatnecha/smartmirror
                            thommy86T 1 Reply Last reply Reply Quote 0
                              akshaybahadur21 @cyberphox
                              @cyberphox https://github.com/raghavpatnecha/smartmirror
                                akshaybahadur21 @shep99
                                @shep99 https://github.com/raghavpatnecha/smartmirror
                                  akshaybahadur21 @cruunnerr
                                  @cruunnerr https://github.com/raghavpatnecha/smartmirror
                                  • thommy86T Offline
                                    thommy86 @akshaybahadur21
                                    @akshaybahadur21 Thanks for the update. What OS are you running MM on? Or what is the best OS to build a MM. I only used a rpi 3 and now going to use an old i7 laptop.
                                    • ChrisC Offline
                                      Chris
                                      I tried to install it on a pc running windows seven pro.
                                      It did not work and I must admit that I did not understand everything in the installation procedure.
                                      Can anyone help me ?
                                      Thank you in advance,
                                      Regards,
                                      akshaybahadur21A bheplerB 2 Replies Last reply Reply Quote 0
                                        akshaybahadur21 @Chris
                                        @Chris not for windows. It requires homebrew and several other packages which are not available on windows.
                                        • ChrisC Offline
                                          Chris
                                          under which operating system is it possible to install it since a raspberry is not powerful enough?
                                          A pc running a Linux operating system? if so, which one is the most suitable?
                                          Regards,
                                          • bheplerB Offline
                                            bhepler Module Developer @Chris
                                            @Chris You might be able to run a virtual machine host on Windows 7 Pro and then run this mirror instance as a VM. Most likely you’ll want to run Ubuntu 16.04 desktop or possibly a version of Debian. @akshaybahadur21 will have the details as to which one.
                                            At work, we use a Debian 9.1.0 installation for slimmed down testing. It doesn’t take up much memory or resources at all.
                                            • 2 / 4
