Having issues loading library
Scheduled Pinned Locked Moved Solved Development
5 Posts 3 Posters 3.0k Views 2 Watching
  • G Offline
    gndimitro
    I’m trying to load annyang but during the loading of my module there is a failure, 404 not found.
    My module code is this:
    Module.register("jarvis", {
      // Required Scripts
      getScripts: function() {
    		return ["annyang.js"];
    Any help would be appreciated, I added the library to package.json and installed it but it won’t load. I tried testing with moment.js and it worked, is there anywhere else I need to reference the library other than package.json?
    G 1 Reply Last reply Aug 8, 2016, 2:12 AM Reply Quote 0
    • G Offline
      gndimitro @gndimitro
      @gndimitro Found the issue, I needed to copy the script to the vendor folder and modify the vendor.js script
      S M 2 Replies Last reply Aug 8, 2016, 10:05 AM Reply Quote 0
        strawberry 3.141 Project Sponsor Module Developer @gndimitro
        @gndimitro when you install a dependency with npm it’s not in your module folder, instead it will be in jarvis/node_modules/annyang/annyang.js
            return [this.file("node_modules/annyang/annyang.js")];
          MichMich Admin @gndimitro
          @gndimitro FYI: to install a 3rd-party module, you should never need to modify any of the core files, like vendor.js.
          G 1 Reply Last reply Aug 9, 2016, 5:38 PM Reply Quote 0
          • G Offline
            gndimitro @MichMich
            @MichMich Thanks! I’ll fix my code accordingly so that I won’t modify vendor.js
