    Controlling Embedded Youtube Video on MM
    23 Posts 6 Posters 17.8k Views 8 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @zichao92
      @zichao92 the access to those functions is limited to the getDom function.
      you should put the definitions outside like
      playthevideo: function() {
      //do the stuff
      and call the function like this.playthevideo()
      Z 1 Reply Last reply Reply Quote 0
      • Z Offline
        zichao92 @strawberry 3.141
        @strawberry-3.141 said in Controlling Embedded Youtube Video on MM:
        //do the stuff
        Hi there,
        I tried your recommendation but i got this error Uncaught TypeError: Cannot read property 'playVideo' of null.
        Which is coming from this code:
        		var myPlayer = document.getElementById('my-video');
        		myPlayer.playVideo();
        I suspect that the problem is that the above function is not being recognise as my embedded youtube codes still lies in the getDom function, which has the allowscriptaccess="awalys" that allows the user to control the video. I tried to extract out from the getDom function but i think my syntax is wrong. Here’s the full code of the youtube function that’s in the getDom function.
        		wrapper.innerHTML='<div> <div>  //(youtube link here ) controls=0&showinfo=0&rel=0&autoplay=1" allowscriptaccess="always" name="my-video" frameborder="0" enablejsapi=1&version=3&playerapiid=ytplayer" type="application/x-shockwave-flash"> allowfullscreen></div></div>';
          @zichao92 because there is no html element that has the id your looking for so var myPlayer = document.getElementById('my-video'); is null
          • Z Offline
            Hi @strawberry-3.141 ,
            Thanks for the clarification!
            I have added id = "my-vdieo" into my code, however, it produced another error :
            Uncaught TypeError: myPlayer.playVideo is not a function
                at Class.playthevideo (youtube.js:69)
            It’s not able to detect the function. After doing some readings about embedded YouTube videos, i came across this site :
            https://developers.google.com/youtube/js_api_reference#onYouTubePlayerReady
            It was mentioned that i require a callback function named onYouTubePlayerReady. The API will call this function when the player is fully loaded and the API is ready to receive calls.
            From there, I should be able to control my video. However, since this function can only be called in getDom function, im not too sure how it should work from here.
              @zichao92 do you have your code on github?
              • Z Offline
                I just uploaded to github ( not too sure if i have done it correctly , first time using github) but here you go.
                https://github.com/zichao92/youtube/tree/Remote-
                Edit 1: I’m still using an older version of Remote Control module by Jopyth, it’s more stable on my MagicMirror( less laggy etc). Im not too sure why though
                  @zichao92 I cleaned up your module
                  Module.register("youtube",{
                      start: function() {
                      getStyles: function() {
                          return ['script.css'];
                      sendCommand: function(cmd){
                          if(myPlayer){
                              myPlayer.contentWindow.postMessage(JSON.stringify({
                                  "event": "command",
                                  "func": cmd
                      notificationReceived: function(notification, payload) {
                          if (notification === "PAUSE_VIDEO"){
                              this.sendCommand("pauseVideo");
                          if (notification === "PLAY_VIDEO"){
                              this.sendCommand("playVideo");
                      getDom: function() {
                          var background = document.createElement("div");
                          background.classList.add("video-background");
                          var foreground = document.createElement("div");
                          foreground.classList.add("video-foreground");
                          var iframe = document.createElement("iframe");
                          iframe.setAttribute("id", "my-video");
                          iframe.setAttribute("src", "https://www.youtube.com/embed/5kIe6UZHSXw?enablejsapi=1&autoplay=1");
                          iframe.setAttribute("frameborder", "0");
                          iframe.setAttribute("type", "text/html");
                          foreground.appendChild(iframe);
                          background.appendChild(foreground);
                          wrapper.appendChild(background);
                          return wrapper;
                  Z E 2 Replies Last reply Reply Quote 1
                  • Z Offline
                    @strawberry-3.141
                    OMG you are life saver. So the whole trick to my module is to use sendcommand instead?
                      @zichao92 not only you had some more issues and sendCommand is a custom method
                        pepebc
                        These modules are very interesting.
                        Would it be possible to use voice command to manage pause and play of youtube?
                        Via notification?
                        Thank you
                        • E Offline
                          E3V3A @strawberry 3.141
                          @strawberry-3.141 Funny how the youtube URL renders within the code tags! :)
                          “Everything I do (here) is for free – altruism is the way!”
                          1 Reply Last reply Reply Quote -1
                            Mykle1 Project Sponsor Module Developer @pepebc
                            @pepebc
                            I had this problem with my Alarm Clock MM and voice commands. Everything works perfectly until the alarm sounds. Now my voice command has to compete with the alarm that is playing. The success rate was pretty low and I was not happy with that. Setting a long enough pause in the alarm sound to issue a voice command seemed to work ok but I wasn’t happy with that either. In the end, I settled for making a clickable button appear when the alarm sounded.
                              pepebc
                              Now I control PLAY and PAUSE through voice commands in the youtube module, instead of with MMM-Remote-Control.
                              I would like to send data like http://localhost:8080 /youtube?Id=XXXXXXX, also with voice, but I can not find the form. The idea is to have a list of videos to play, automated by voice. Any idea?
                              It could become a very interesting module…
