    Module Developer Challenge - I surrender!
    Scheduled Pinned Locked Moved Solved Development
    33 Posts 6 Posters 22.6k Views 5 Watching
      A Former User @Mykle1
      @Mykle1
      This is not the result of deep-thought, but… In many cases, it might be related to the cache. So I suggest you try the traditional solution about this kind of problem.
      Add some random value to the url for refreshing cache when you try to load the new image like this.
      http://api.usno.navy.mil/imagery/earth.png?date=today&seed=[SomeRandomValue]
      However this might be not the solution, but I think it has worthy to try.
      strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 3
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @Guest
        @Sean actually the problem starts even before the cache. the way magicmirror is designed in the update module function is, that it will only rerender if there was something changed in the dom. But your solution should still fix the problem.
        Another similar way would be to put a “seed” to the dom element itself insetad of the url, as i suggested in the iframe reload module, which fixed the reload problem there.
        after line 147
        img.setAttribute("timestamp", new Date().getTime());
        which will create an dom element like:
        < img class="photo" timestamp="1508693514656" src="http://api.usno.navy.mil/imagery/earth.png?date=today" />
        • Mykle1M
          @Sean
          @strawberry 3.141
          Oh hey, thanks to you both. I just got in from my daughter’s. I was playing with my grandchildren. I will give those a try right now. You guys are awesome!
          I’ll post back with my results.
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @Guest
            @Sean said in Module Developer Challenge - I surrender!:
            Hi Sean,
            I tried your suggestion first as yours was the first suggestion.
            I added a var for random number between 1 and 99
            var randomNumber = Math.floor(Math.random() * 99);
            And inserted that into the url
            img.src = "http://api.usno.navy.mil/imagery/earth.png?date=today&seed=" + randomNumber;
            Console log reporting that the random number is being generated
            http://api.usno.navy.mil/imagery/earth.png?date=today&seed=16
            MMM-SunRiseSet.js:157 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=5
            MMM-SunRiseSet.js:157 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=75
            MMM-SunRiseSet.js:157 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=31
            MMM-SunRiseSet.js:157 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=12
            MMM-SunRiseSet.js:157 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=16
            Many thanks to you, Sean. The module IS updating now!
            Now, on to try @strawberry’s suggestion!
            EDIT
            I set the above to run on my MacBuntu laptop running MM so I could monitor it. It was updating nicely for a while but then something odd happened. An update resulted in an earlier image being loaded. I think this is because random numbers between 1 - 99 will at some point choose the same number.
            I’ll continue to work on it. I have an idea!
              @Mykle1 I think 99 is somehow too small. Use bigger values or timestamp for preventing duplicated.
              • Mykle1M
                Yes, see the edit to my post. I was writing that as you posted.
                I’ll report back
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @strawberry 3.141
                  @strawberry-3.141
                  So, after having tried Sean’s suggestion I realized my mistake in using a random number instead of timestamp. As I was about to try your suggestion I realized that I could use a part of Sean’s suggestion and a part of your suggestion.
                  I had already set up a var for random numbers, so I changed that to var getTimeStamp = new Date().getTime(); which was your idea added to Sean’s idea of a random value. A quick check in the console showed me it was working.
                  http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508717386975
                  MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508717686862
                  MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508717686866
                  MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508717987939
                  MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508717987944
                  MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508718287819
                  MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508718287823
                  Then a simple edit to the url which was kinda, sorta, like the ideas you both had.
                  img.src = "http://api.usno.navy.mil/imagery/earth.png?date=today&seed=" + getTimeStamp;
                  And BOOM! Success! I’ll leave it running all night and check it in the morning but I don’t foresee any problems
                  So, thank you Strawberry and thank you Sean. You guys are truly amazing!!!
                  Commence embarrassment recovery
                  • Mykle1M
                    So far, so good. I have it running on my MacBuntu laptop. Here is a 2 frame animation so you get the idea. Obviously, there are quite a few updates absent from the gif and the shadow will move much more slowly and not jump across the planet. hehe
                    • Mykle1M
                      I am happy to report that the module ran for the last 11 hours without a hitch. The visual image shows day and night exactly where it should.
                      • Mykle1M
                        I find myself in a similar situation, again. :-)
                        This is my cry for help. I only do this when I’ve tried all the things I know
                        and googled the things I don’t know. I’ve even tried free form improvising but coding
                        seems to reject that sort of thing, at least in my case.
                        About 2 weeks ago I wrote a module that gets system stats from a PC board running
                        ubuntu and MM. There is just one more thing that I want to include. I want to get the system
                        temperature (CPU?) and/or the temps of any other system components.
                        So, it is with the utmost humility that I ask for your help, suggestions or directions. I won’t
                        object to any modifications that anyone cares to make, if that is the case. If it can’t be done,
                        I can live with that, too. Even if you look at the module and never make any comments regarding
                        my request, I still thank you for your time and interest.
                        https://github.com/mykle1/MMM-PC-Stats
                        Peace
                        • N
                          ninjabreadman @Mykle1
                          @Mykle1 It doesn’t seem that pc-stats has all the info you require. You might consider switching to the systeminformation package.
                          You can then use si.cpu() for your CPU stats and si.cpuTemperature() to retrieve an object that (if I read the docs right) looks like { main: 0, max: 0, cores: [0, 0] } with your core temps. You can then combine the two responses (or you may be able to have it return all within one request) and return those in a single sendNotification() call.
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @ninjabreadman
                            @ninjabreadman
                            You know, I started out with that package but had some trouble with it. Likely, the problem was me, but I moved to the pc-stats package and had no problems. However, as you saw, that package doesn’t offer the cpu temps. I then tried unsuccessfully to use other packages along with pc-stats to get the temps but my knowledge and abilities are woefully inadequate. For whatever reason, I was able to get a return from pc-stats. That’s no small miracle where I’m concerned. I do like the data that the return gives me, especially the multicore support.
                            Anyway, I did give it more than a few days and more than a few attempts but I will look at systeminformation again in the hopes that I can stumble across some success. Really, I am not qualified to be doing any of this. I just find it so fascinating that I keep trying until I get something right. And then there are the few special people that have taken pity on me and taught me what I needed to know at any given moment. They have my deepest gratitude and respect.
                            Thanks for pointing me back to where I should have been all along. :-)
                            • N
                              @Mykle1 Depending on the style/implementation you’re using, you may want to read up on Promises in JS.
                              Also, see this note here about the lm-sensors package.
                              Alternatively, have a look at MMM-SystemStats which uses vcgencmd on the CLI to retrieve the system temp, which would be far easier to integrate into your current module.
                              • Mykle1M
                                @ninjabreadman said in Module Developer Challenge - I surrender!:
                                Thanks ninja. I will give this a shot first. In fact, I’m going to look at that right now.
                                N 1 Reply Last reply Reply Quote 1
                                • N
                                  @Mykle1 Hmm, it may be that vcgencmd is specific to the RPi. You can try these; acpi seems like a contender, as does lm-sensors.
                                  • Mykle1M
                                    Ha! I see. Ok, on to the others. :-)
                                    • N
                                      @Mykle1 It actually might be best to run cat /sys/class/thermal/thermal_zone*/type to see if they’re already populating on your Ubuntu install. If so, you can run cat /sys/class/thermal/thermal_zone*/temp to get all the values, or just cat a specific one. Should be to three decimal places (i.e. 64000 means 64.000°C).
                                      You might run it a few times to see that the values change, and if they do, then use the same exec() method from MMM-SystemStats with the right command and some math.
                                      • Mykle1M
                                        Made some progress with lm-sensors which gives me great hope. I can see the return in the terminal but not in the node_helper. Still, I’m encouraged. I’ll continue to work on it tomorrow. I’m feeling a bit tired tonight.
                                        Launching application.
                                        { 'nouveau-pci-0100': { 'PCI adapter': { temp1: [Object] } },
                                          'coretemp-isa-0000':
                                           { 'ISA adapter':
                                              { 'Core 0': [Object],
                                                'Core 1': [Object],
                                                'Core 2': [Object],
                                                'Core 3': [Object] } } }
                                        TypeError: this.sendSocketNotification is not a function
                                            at /home/pop/MagicMirror/modules/MMM-PC-Stats/node_helper.js:32:9
                                            at /home/pop/MagicMirror/modules/MMM-PC-Stats/node_modules/sensors.js/lm-sensors.js:96:12
                                            at ChildProcess.exithandler (child_process.js:209:7)
                                            at emitTwo (events.js:106:13)
                                            at ChildProcess.emit (events.js:194:7)
                                            at maybeClose (internal/child_process.js:899:16)
                                            at Socket. (internal/child_process.js:342:11)
                                            at emitOne (events.js:96:13)
                                            at Socket.emit (events.js:191:7)
                                            at Pipe._handle.close [as _onclose] (net.js:510:12)
                                        • E
                                          E3V3A @Mykle1
                                          @Mykle1 Not sure what you’re doing in your code. But…
                                          1. You’ll get a temp reading for each cpu core, so you need to choose|add|average…, and
                                          2. How do you execute the script? Did you give it proper permissions?
                                          3. I’m you already know, but you also need to allow the external file to be read from node_helper.js.
                                          “Everything I do (here) is for free – altruism is the way!”
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @E3V3A
                                            @E3V3A said in Module Developer Challenge - I surrender!:
                                            Neither am I. :-)
