    Module Developer Challenge - I surrender!
    Scheduled Pinned Locked Moved Solved Development
    33 Posts 6 Posters 22.1k Views 5 Watching
      Mykle1 Project Sponsor Module Developer @Guest
      @Sean said in Module Developer Challenge - I surrender!:
      I think 99 is somehow too small. Use bigger values or timestamp for preventing duplicated.
      Yes, see the edit to my post. I was writing that as you posted.
      I’ll report back
        Mykle1 Project Sponsor Module Developer @strawberry 3.141
        @strawberry-3.141
        So, after having tried Sean’s suggestion I realized my mistake in using a random number instead of timestamp. As I was about to try your suggestion I realized that I could use a part of Sean’s suggestion and a part of your suggestion.
        I had already set up a var for random numbers, so I changed that to var getTimeStamp = new Date().getTime(); which was your idea added to Sean’s idea of a random value. A quick check in the console showed me it was working.
        http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508717386975
        MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508717686862
        MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508717686866
        MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508717987939
        MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508717987944
        MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508718287819
        MMM-SunRiseSet.js:166 http://api.usno.navy.mil/imagery/earth.png?date=today&seed=1508718287823
        Then a simple edit to the url which was kinda, sorta, like the ideas you both had.
        img.src = "http://api.usno.navy.mil/imagery/earth.png?date=today&seed=" + getTimeStamp;
        And BOOM! Success! I’ll leave it running all night and check it in the morning but I don’t foresee any problems
        So, thank you Strawberry and thank you Sean. You guys are truly amazing!!!
        Commence embarrassment recovery
          So far, so good. I have it running on my MacBuntu laptop. Here is a 2 frame animation so you get the idea. Obviously, there are quite a few updates absent from the gif and the shadow will move much more slowly and not jump across the planet. hehe
            I am happy to report that the module ran for the last 11 hours without a hitch. The visual image shows day and night exactly where it should.
              I find myself in a similar situation, again. :-)
              This is my cry for help. I only do this when I’ve tried all the things I know
              and googled the things I don’t know. I’ve even tried free form improvising but coding
              seems to reject that sort of thing, at least in my case.
              About 2 weeks ago I wrote a module that gets system stats from a PC board running
              ubuntu and MM. There is just one more thing that I want to include. I want to get the system
              temperature (CPU?) and/or the temps of any other system components.
              So, it is with the utmost humility that I ask for your help, suggestions or directions. I won’t
              object to any modifications that anyone cares to make, if that is the case. If it can’t be done,
              I can live with that, too. Even if you look at the module and never make any comments regarding
              my request, I still thank you for your time and interest.
              https://github.com/mykle1/MMM-PC-Stats
              Peace
              • N Offline
                ninjabreadman @Mykle1
                @Mykle1 It doesn’t seem that pc-stats has all the info you require. You might consider switching to the systeminformation package.
                You can then use si.cpu() for your CPU stats and si.cpuTemperature() to retrieve an object that (if I read the docs right) looks like { main: 0, max: 0, cores: [0, 0] } with your core temps. You can then combine the two responses (or you may be able to have it return all within one request) and return those in a single sendNotification() call.
                  Mykle1 Project Sponsor Module Developer @ninjabreadman
                  @ninjabreadman
                  You know, I started out with that package but had some trouble with it. Likely, the problem was me, but I moved to the pc-stats package and had no problems. However, as you saw, that package doesn’t offer the cpu temps. I then tried unsuccessfully to use other packages along with pc-stats to get the temps but my knowledge and abilities are woefully inadequate. For whatever reason, I was able to get a return from pc-stats. That’s no small miracle where I’m concerned. I do like the data that the return gives me, especially the multicore support.
                  Anyway, I did give it more than a few days and more than a few attempts but I will look at systeminformation again in the hopes that I can stumble across some success. Really, I am not qualified to be doing any of this. I just find it so fascinating that I keep trying until I get something right. And then there are the few special people that have taken pity on me and taught me what I needed to know at any given moment. They have my deepest gratitude and respect.
                  Thanks for pointing me back to where I should have been all along. :-)
                  • N Offline
                    @Mykle1 Depending on the style/implementation you’re using, you may want to read up on Promises in JS.
                    Also, see this note here about the lm-sensors package.
                    Alternatively, have a look at MMM-SystemStats which uses vcgencmd on the CLI to retrieve the system temp, which would be far easier to integrate into your current module.
                      @ninjabreadman said in Module Developer Challenge - I surrender!:
                      Thanks ninja. I will give this a shot first. In fact, I’m going to look at that right now.
                      N 1 Reply Last reply Reply Quote 1
                      • N Offline
                        @Mykle1 Hmm, it may be that vcgencmd is specific to the RPi. You can try these; acpi seems like a contender, as does lm-sensors.
                          Ha! I see. Ok, on to the others. :-)
                          • N Offline
                            @Mykle1 It actually might be best to run cat /sys/class/thermal/thermal_zone*/type to see if they’re already populating on your Ubuntu install. If so, you can run cat /sys/class/thermal/thermal_zone*/temp to get all the values, or just cat a specific one. Should be to three decimal places (i.e. 64000 means 64.000°C).
                            You might run it a few times to see that the values change, and if they do, then use the same exec() method from MMM-SystemStats with the right command and some math.
                              Made some progress with lm-sensors which gives me great hope. I can see the return in the terminal but not in the node_helper. Still, I’m encouraged. I’ll continue to work on it tomorrow. I’m feeling a bit tired tonight.
                              Launching application.
                              { 'nouveau-pci-0100': { 'PCI adapter': { temp1: [Object] } },
                                'coretemp-isa-0000':
                                 { 'ISA adapter':
                                    { 'Core 0': [Object],
                                      'Core 1': [Object],
                                      'Core 2': [Object],
                                      'Core 3': [Object] } } }
                              TypeError: this.sendSocketNotification is not a function
                                  at /home/pop/MagicMirror/modules/MMM-PC-Stats/node_helper.js:32:9
                                  at /home/pop/MagicMirror/modules/MMM-PC-Stats/node_modules/sensors.js/lm-sensors.js:96:12
                                  at ChildProcess.exithandler (child_process.js:209:7)
                                  at emitTwo (events.js:106:13)
                                  at ChildProcess.emit (events.js:194:7)
                                  at maybeClose (internal/child_process.js:899:16)
                                  at Socket. (internal/child_process.js:342:11)
                                  at emitOne (events.js:96:13)
                                  at Socket.emit (events.js:191:7)
                                  at Pipe._handle.close [as _onclose] (net.js:510:12)
                              • E Offline
                                E3V3A @Mykle1
                                @Mykle1 Not sure what you’re doing in your code. But…
                                1. You’ll get a temp reading for each cpu core, so you need to choose|add|average…, and
                                2. How do you execute the script? Did you give it proper permissions?
                                3. I’m you already know, but you also need to allow the external file to be read from node_helper.js.
                                “Everything I do (here) is for free – altruism is the way!”
                                  Mykle1 Project Sponsor Module Developer @E3V3A
                                  @E3V3A said in Module Developer Challenge - I surrender!:
                                  Neither am I. :-)
                                  • strawberry 3.141S Offline
                                    strawberry 3.141 Project Sponsor Module Developer @Mykle1
                                    @Mykle1 you might want to upload your current version to a github branch so we can see what your doing
                                    • cowboysdudeC Offline
                                      He can’t it’s a secret HAHHAHAHAHHA
                                        I would like to thank everyone that gave me suggestions and advice. I really do appreciate the support.
                                        I ended up using a combination of 2 npm packages. pc-stats and sensors.js. My first time building a module from an npm package, and then adding a second to the same module confused me quite a bit. That, and my lack of any real coding experience, found me at a standstill.
                                        Well, once again, @cowboysdude took pity on me. He took the time to teach me where I went wrong, and what I was missing, and what I didn’t need. Maybe I won’t retain everything that he taught me but I will certainly remember his kindness and generosity. His patience is astonishing. :-)
                                        Now I just need some formatting if anyone cares to assist me with that. Anyway, here’s a quick shot. Ideally, I would like to move the Core temps to right, just under the video card temp
                                          @cowboysdude said in Module Developer Challenge - I surrender!:
                                          My code (if you can even call it that) is never a secret. It’s more like an embarrassing teenager moment. ;-)
                                          However, I do enjoy learning and I do appreciate you taking the time to teach me. You’re a damn good dude! :-)
                                          E 1 Reply Last reply Reply Quote 1
                                          • N Offline
                                            @Mykle1 Glad to hear you got it working!
                                            Is this your dev environment? Or do you really have an i7 780, GTX 660 and 16Gb running MM? At least it can run MMM-Globe!
