    Adding a jQuery Module
    7 Posts 4 Posters 4.3k Views 4 Watching
    • morozgrafixM Offline
      morozgrafix Moderator @strawberry 3.141
      In addition to @strawberry-3.141 response. I wanted to chime in with option of running it locally on your dev machine and using node serveronly and pointing your browser at http://localhost:8080 using familiar tools while developing. One of the catches is it will not work well if you are developing module that needs to interact with GPIO or other proprietary RasPi functionality.
      My personal workflow is roughly outlined here: https://forum.magicmirror.builders/post/13272
      • N Offline
        NiviJah
        Thank you,
        This is very helpful.
        If I understand correctly, do I need to use DOM_OBJECTS_CREATED like this ?
        notificationReceived: function(notification, payload, sender){
        	if (notification === 'DOM_OBJECTS_CREATED'){
        		$(document).ready().....
        Does that go into my plugin file ? (i.e not the node helper)
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @NiviJah
          @NiviJah your Code example is correct, except that you don’t Need the ready function, at this Point the Dom is ready and you can do whatever You Wanted to without wrapping it into another event
          • N Offline
            NiviJah
            jQuery didn’t want to play nice, i don’t know why, so I had to work with Vanilla JS.
            here is the result
            E 1 Reply Last reply Reply Quote 1
            • E Offline
              E3V3A @NiviJah
              @NiviJah Did you get jQuery to run at all?
              "Everything I do (here) is for free – altruism is the way!"
