    ECONNREFUSED when trying to get JSON from my server (MMM-json-feed)
    10 Posts 4 Posters 3.2k Views 3 Watching
    • N Offline
      ninjabreadman @E3V3A
      @toh1000 Can you reach the JSON service with curl on your MM machine? And @e3v3a is right – ideally put the response through a validator, especially for things like trailing commas.
      • N Offline
        @E3V3A Also, @toh1000’s HTTP request included the header Accept-Encoding: gzip, deflate, so the test site responded with Content-Encoding: gzip. That’s totally appropriate, and usually this is handled transparently by the client, which will then provide the uncompressed response. However, the actual service (“My service”) responded with no compression.
        • E Offline
          E3V3A
          From here:
          ECONNREFUSED (Connection refused): No connection could be made because the target machine
          actively refused it. This usually results from trying to connect to a service that is inactive on the
          foreign host.
          "Everything I do (here) is for free – altruism is the way!"
          • cowboysdudeC Offline
            Here’s an example in my node helper I use to get json
            request({
                        url: "xxxxxxxxxxxx.json",
                        method: 'GET',
                        headers: {
                            'User-Agent': 'MagicMirror/1.0 (' + this.config.email + ')'
            • T Offline
              toh1000 @ninjabreadman
              @ninjabreadman Yes, curl call returns correct json:
              {"Date": "22.02.2018", "Temperature": -0.187, "Time": "22:45:37"}
              • T Offline
                toh1000 @E3V3A
                @E3V3A Any idea what I could do to accept the connection?
                • T Offline
                  toh1000 @cowboysdude
                  @cowboysdude I added the header (without the this.config.email) but got the same result.
                  • T Offline
                    toh1000
                    Solved:
                    The problem was that the module translated the server name into an up address and CherryPy was not configured to response to that.
                    Reconfiguring did the trick:
                    this article explains how this is done
                    Thanks for your efforts.
