    ECONNREFUSED when trying to get JSON from my server (MMM-json-feed)
    10 Posts 4 Posters 3.2k Views 3 Watching
    • N Offline
      ninjabreadman @E3V3A
      @E3V3A Also, @toh1000’s HTTP request included the header Accept-Encoding: gzip, deflate, so the test site responded with Content-Encoding: gzip. That’s totally appropriate, and usually this is handled transparently by the client, which will then provide the uncompressed response. However, the actual service (“My service”) responded with no compression.
      • E Offline
        E3V3A
        From here:
        ECONNREFUSED (Connection refused): No connection could be made because the target machine
        actively refused it. This usually results from trying to connect to a service that is inactive on the
        foreign host.
        "Everything I do (here) is for free – altruism is the way!"
        • cowboysdudeC Offline
          Here’s an example in my node helper I use to get json
          request({
                      url: "xxxxxxxxxxxx.json",
                      method: 'GET',
                      headers: {
                          'User-Agent': 'MagicMirror/1.0 (' + this.config.email + ')'
          • T Offline
            toh1000 @ninjabreadman
            @ninjabreadman Yes, curl call returns correct json:
            {"Date": "22.02.2018", "Temperature": -0.187, "Time": "22:45:37"}
            • T Offline
              toh1000 @E3V3A
              @E3V3A Any idea what I could do to accept the connection?
              • T Offline
                toh1000 @cowboysdude
                @cowboysdude I added the header (without the this.config.email) but got the same result.
                • T Offline
                  toh1000
                  Solved:
                  The problem was that the module translated the server name into an up address and CherryPy was not configured to response to that.
                  Reconfiguring did the trick:
                  this article explains how this is done
                  Thanks for your efforts.
