This forum was moved to another machine and updated to a recent version. If you are unable to login please delete your browser cookies and cache and restart your browser.A New Chapter for MagicMirror: The Community Takes the Lead
MM docker container problem with mac and linux
@raywo The config.js.sample was created automatically. After that i copy it to config.js and restarted container but logs show:
Ready to go! Please point your browser to: http://localhost:8080 Starting MagicMirror: v2.1.3 Loading config ... Loading module helpers ... No helper found for module: clock. All module helpers loaded. Starting server on port 8080 ... Server started ... Sockets connected & modules started ... Ready to go! Please point your browser to: http://localhost:8080
@tomasz2101 And? Does it work?
@raywo no
@tomasz2101 In my
config.js
I put""
in theaddress
setting. I also have"::ffff:192.168.2.1/120"
included in myipWhitelist
. My home network is192.168.2.0
.my
config.js
var config = { address: "", // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.2.1/120", "192.168.2.110", "172.17.0.1"] /* module config */ }
@raywo thx a lot now it is working.
Also i had to do docker binding to localhost
my config:var config = { address: "", port: 8080, ipWhitelist: [], language: "en", timeFormat: 24, units: "metric", modules: [ { module: "clock", position: "top_left" } ] };
I updated the Github repository to include a working config file example. Thanks @raywo!
@bastilimbach Good addition to the docs. Thank you!
Maybe you should remove"192.168.2.1/120", "192.168.2.110"
as it applies only to my configuration. Or you should explain it better. -
@raywo Oh yes you’re absolutely right.
