Custom module to run python script
4 Posts 4 Posters 3.6k Views 4 Watching
    sureshkocherla
    I have one python script. I want to create a new custom module to run the python script automatically
    Kindly guide me.
      Sputnik
      I would like to do the same thing :-)
      S 1 Reply Last reply Mar 5, 2018, 8:08 PM Reply Quote 1
        pinsdorf Module Developer
        A good starting point might be the module MMM-dht by @nebulx29. It executes a custom shell command to read data from a sensor. You’ll find the invocation of the script in file node_helper.js. NB: it makes three calls, because it needs three values from the sensor.
        In your use case, you’d call Python with your script name instead.
          strawberry 3.141 Project Sponsor Module Developer @Sputnik
          @Sputnik the facerecognition moduel of @paviro makes also heavy use of python scripts, take a look here https://github.com/paviro/MMM-Facial-Recognition/blob/master/node_helper.js
