    Need more compliments? compliments.json
    Scheduled Pinned Locked Moved Fun & Games
    16 Posts 8 Posters 12.2k Views 8 Watching
      ryck Module Developer
      I always like to expand the default compliments a little bit (using an external json file), so I guess I can share it as well:
      https://gist.github.com/ryck/e28a69665b8839f6e9a7acd6b4acc97d
      1 Reply Last reply Reply Quote 4
      • E Offline
        E3V3A
        "Everything I do (here) is for free – altruism is the way!"
          dmd
          First of all, thanks for the new compliments! But I’m a noob and I can’t seem to figure this out. As I understand, first you copy this file to: pi@raspberrypi:~/MagicMirror/modules/default/compliments
          Do I have to edit config.js or compliments.js and what exactly do I put there?
            ryck Module Developer @dmd
            @dmd Just add remoteFile: “compliments.json” to the compliments module configuration
            A 1 Reply Last reply Reply Quote 1
            • G Offline
              gotchabeats
              i still cant figure it out. How do i remote to the file?
                sdetweil @gotchabeats
                @gotchabeats you don’t its just a word…
                means the compliments are the file, not in config.js
                just
                module: 'compliments',
                     remoteFile: 'whatever the filename is',
                • G Offline
                  gotchabeats
                  @sdetweil said in compliments.json:
                  just
                  thanks that worked
                    amanzimdwini @ryck
                    @ryck
                    I was wondering how I can just link to a LOCAL file (instead of your github): I’d like to change the contents.
                    (Yes, I could copy to my OWN github and modify, but that seems a bit wierd).
                    I have to date failed with
                    remoteFile: "~\MagicMirror\config\compliments.json"
                    where I had copied your file to.
                    What am I missing?
                    Karl
                      ryck Module Developer @amanzimdwini
                      @amanzimdwini I always use it locally, github is just a place for sharing it, so you are doing the right thing. You can always fork it to keep your personal compliments safe, but that’s up to you.
                      To use it, copy the file to somewhere (ie, in the compliments module folder: modules/default/compliments/compliments.js) and use it in your config like this:
                            module: "compliments",
                            position: "bottom_bar",
                            disabled: false,
                              remoteFile: "compliments.json",
                              updateInterval: 10000,
                              classes: "thin bright medium",
                              fadeSpeed: 2000,
                      Good luck!
                      P A 2 Replies Last reply Reply Quote 0
                        pastormingle @ryck
                        @ryck Do you know if compliments can be set to fit a grid? I have it at the top right about my todo list and when it rotates it causes the todo to also change in size?
