    Pi Zero
    pizero
    37 Posts 10 Posters 58.8k Views 12 Watching
    • N
      nigel-daniels
      I’ve just tried out running MM2 on a Pi0. It all seems to load up using the server only but when I fire up kweb I just end up with a blank screen. This was a new install so I used the basic config file and added my own data (e.g. weather app key, etc.). I’m new to using MM2 as well so I was not sure if I should be seeing lines like:
      No helper found for module: nnnn
      As far as I can tell the calendar and newsfeed have started, but nothing is displayed :(
      Any recommendations on the diagnostic steps I need to take?
      • KirAsh4K
        KirAsh4 Moderator
        Hopefully the community can help you out here as the Pi0 is not supported. Some people may have gotten it to work though …
        N 1 Reply Last reply
        • MitchfarinoM
          Mitchfarino Module Developer
          @evos I’ve only just seen this. Awesome work! I’ll check it out!
          This means I can free up my Pi3 for something else
          • N
            Neokamikaze
            Hi All,
            MM2 works on Pi0. If you want install MM2 on Pi0 use the @evos process or use my install file.
            MagicMirrorInstallPi0.sh
            N 2 Replies Last reply
            • N
              nigel-daniels @Neokamikaze
              @Neokamikaze thanks, I’d manually got to the same sort of place the script would have got me to… It would have got me there faster ;) Further testing has shown it was my set up of kweb that was at fault not MM2 (the page loaded correctly with firefox). I was testing the page in regular browser mode before using kiosk mode so I can perfect my own config.sh. It turned out I had jScript and cookies off, with these enabled fixed the issue I was seeing.
              Thanks for all your great work on getting MM2 working on the Pi0!
              • N
                nigel-daniels @KirAsh4
                @KirAsh4 it may be worth getting the support statement updated to the same level as using the Pi1, the Pi0 will run MM2 quite happily using ‘node serveronly’… in my case it turn out you just need to be sure kweb is set up correctly if that is the browser of choice ;)
                  darkeagl105
                  I can confirm. It is working with pi 1 in server only mode and kweb. Just some modules don’t show like mmm-sonos. If you connect with anotrr machine with chrome it works normally so it is a browser problem :( and I couldn’t find a solution for that till now
                  • N
                    nigel-daniels @darkeagl105
                    @darkeagl105 I found out with kweb you must enable cookies and Java Script for anything to work. So far I’ve only tested with the default modules, if I find out more about the non-default modules I’ll post here. Kweb is nice and light, I tried firefox but the Pi0 struggles to run it.
                    D 1 Reply Last reply
                      darkeagl105 @nigel-daniels
                      @nigel-daniels I know tried it with all kind of browser and stick with kweb. Will try this weekend with my settings and a pi0 to confirm it as well. I was using a Pi1 B+
                      • N
                        nigel-daniels
                        Has anyone encountered the following issue with kweb. I got everything up and running on the Pi0 and used the platform to develop a new module MMM-FAA-Delay. I then stopped VNC from auto starting, set the boot to console with pi logged in, reinstated the autostart MM2 and kweb script. However this time I also set the screen rotation in config.txt. Everything works fine but it looks like kweb is still using the previous screen ratio even though it’s rotated. i.e. it only fills the top third or so of the screen and the left hand side is ‘off screen’.
                        Any thoughts?
                        • N
                          nigel-daniels @nigel-daniels
                          @nigel-daniels Follow up I just did a full reinstall, Kweb now seems to get the screen width of the rotated screen but still only uses the upper third portion of the screen :( Any thoughts on how I tell it the screen height.
                          • N
                            @nigel-daniels Ok deeper digging into the kweb code has revealed that the ratio options are hard coded :( I’ve put a request to the Kweb authors for this to be an option. As a short term hack you can install kweb as per @Neokamikaze suggested, then:
                            git clone https://github.com/ekapujiw2002/kweb
                            sudo apt-get install webkitgtk-3.0
                            Then open up kweb.c and change one of the parameter settings to be the ratio you need, for example I set 8 to be 1080x1920. Then make the kweb code and replace /usr/bin/kweb with your custom binary. Now alter the start.sh to use the number you chose for your custom ratio.
                            • N
                              @Neokamikaze hi, what did you do to stop the screen from blanking? Having got the kweb and MM running perfectly I set this up to run without screen blanking an got the mirror in position… but it still blanks after about 10 mins+. The steps I took were:
                              Turn off the monitors energy saving mode.
                              I then edited ~/.config/lxsession/LXDE-pi/autostart and /etc/xdg/lxsession/LXDE-pi/autostart commented out the screensaver line and added:
                              @xset s off
                              @xset -dpms
                              @xset s noblank
                              Finally in /etc/kbd/config I set the following to:
                              BLANK_TIME=0
                              BLANK_DPMS=off
                              POWERDOWN_TIME=0
                              What am I missing here?
                              • N
                                Neokamikaze
                                Hi @nigel-daniels, i don’t touch kweb configuration. I just add on “~/.config/lxsession/LXDE-pi/autostart” file this:
                                @lxpanel --profile LXDE-pi
                                @pcmanfm --desktop --profile LXDE-pi
                                @xscreensaver -no-splash
                                and in “/etc/xdg/lxsession/LXDE-pi/autostart” this:
                                @xset s noblank
                                @xset s off
                                @xset -dpms
                                After for configure my display i change the configuration in “/boot/config.txt”.
                                • N
                                  @Neokamikaze HI thanks for the suggestion, I’ve ensured both my versions of these files match yours, but somewhere DPMS is being enabled… 10 mins in the screen blanks. I can see in the file /var/log/Xorg.0.log the following lines:
                                  [ 81.864] (II) FBTURBO(0): enabled fbdev copyarea acceleration
                                  [ 81.865] (==) FBTURBO(0): Backing store enabled
                                  [ 81.875] (==) FBTURBO(0): DPMS enabled
                                  [ 81.875] (II) FBTURBO(0): failed to enable hardware cursor
                                  Something somewhere is setting DPMS up and for some reason the xset -dpms command is being skipped. I’ll try adding the set command to the start.sh and see if that forces the issue.
                                  • N
                                    Neokamikaze
                                    Hi @nigel-daniels, if you use jessie i think there is a problem with DPMS. There is a GUI package for configure this. If you want test install “xscreensaver” package
                                    • N
                                      @Neokamikaze Thanks I’ll give that a shot. This is Jessy, and it sounds like the sort of problem I’m seeing.
                                      Me thinks it will need to be in the morning now… gone midnight in my TZ so I’ll get screensaver on board and deal with pulling the mirror apart to get the minikbd plugged back in till then.
                                      I’ll let you know how it works out.
                                      • N
                                        @nigel-daniels sigh ok tried that rebooted into the GUI and used the screensaver config to switch off the screensaver. Then reconfigured the system to log into the CLI and use the start.sh to kick of X/Kweb… 10 mins later a black screen. I’m running out of locations to try using the set commends, I even added them to the start.sh.
                                          darkeagl105
                                          So my promised input to the whole thing:
                                          I gave up on kweb and using midori browser. It automaticly starts in fullscreen and kiosk mode. I have to put in a delay after “node serveronly” of 45s.
                                          Bootup in console mode and add this in /etc/rc.local
                                          sudo -u mirror /home/mirror/MagicMirror/serveronly
                                          sleep 45s;
                                          sudo -u mirror midori -e Fullscreen -a http://localhost:8080
                                          and thats it. Works for me.
                                          • N
                                            @darkeagl105 HI thanks for the update, I did end up recompiling Kweb which worked once I’d figured out I had to do that… I’m just now stuck figuring out how to stop my screen blanking after 10 mins! I think I’ve added the xset commands in about 5 locations and still nothing!
                                            H 1 Reply Last reply
