    Pi Zero
    pizero
    37 Posts 10 Posters 58.2k Views 12 Watching
      Mitchfarino Module Developer
      I’ve just ordered a Pi Zero, so was wondering whether MM2 would run fine on that?
      I’m guessing / hoping so, as this will allow me to use my Pi3 for something else.
        jfi1310
        I’m very interested too! Can anyone help us?
        • MichMichM
          MichMich
          It probably can, because the specs are better than the Pi2. But since you’ll need a lot of extra accessories (usb Wifi, mini HDMI to HDMI convertor), it’s probably cheaper to use a Pi2 or Pi3.
            Mitchfarino Module Developer @MichMich
            @MichMich I was just thinking of lower power consumption, plus it would free up my Pi3 for something else :smiley:
              jfi1310
              I’ve read something about no support for the Zero. The specs are good enough I think, but is it supported by the software?
              I already have a Zero and a wifi dongle, so it would definetely be cheaper. And less space necessary…
                Mitchfarino Module Developer @jfi1310
                @jfi1310 it may have been me who replied to you. As I was told the zero wasnt supported.
                I’m the same, I’ve got a WiFi adapter etc for mine
                • MichMichM
                  MichMich
                  Well I personally never tried it, but I don’t see a reason why it shouldn’t work … :)
                    jfi1310
                    There’s this topic:
                    https://forum.magicmirror.builders/topic/201/sudo-npm-start-does-nothing-on-a-pi-zero/12
                    Is it a problem especially with the Pi Zero or just because of the card switching?
                      jfi1310
                      I just tried to install it on the Pi Zero but there was this message:
                      No Chance?
                      • MichMichM
                        MichMich
                        Hmmm … it seems the Zero is running on ARMv6. Just like the the Pi 1. Unfortunately, Electron (the browser frame on which MagicMirror relies) does not support ARMv6. You can install MagicMirror² and just use the serveronly method, but you would need to setup a browser in kiosk mode yourself. Which is tricky on the ARMv6 platform.
                        • N
                          Neokamikaze
                          I modify the installation file for Pi0. But the program don’t start. My Post “npm-do-not-start”
                          and the file.
                          0_1469782479446_MagicMirrorInstallPi0.sh
                          I don’t find the solution for the moment.
                          • N
                            Neokamikaze
                            Ok thanks
                            • N
                              Neokamikaze
                              Now is ok for the Pi0. But just for install Kweb.
                              i use this commands:
                              wget http://steinerdatenbank.de/software/kweb-1.7.3.tar.gz
                              tar -xzf kweb-1.7.3.tar.gz
                              cd kweb-1.7.3
                              ./debinstall
                              • N
                                nigel-daniels
                                I’ve just tried out running MM2 on a Pi0. It all seems to load up using the server only but when I fire up kweb I just end up with a blank screen. This was a new install so I used the basic config file and added my own data (e.g. weather app key, etc.). I’m new to using MM2 as well so I was not sure if I should be seeing lines like:
                                No helper found for module: nnnn
                                As far as I can tell the calendar and newsfeed have started, but nothing is displayed :(
                                Any recommendations on the diagnostic steps I need to take?
                                • K
                                  KirAsh4 Moderator
                                  Hopefully the community can help you out here as the Pi0 is not supported. Some people may have gotten it to work though …
                                    @evos I’ve only just seen this. Awesome work! I’ll check it out!
                                    This means I can free up my Pi3 for something else
                                    • N
                                      Neokamikaze
                                      Hi All,
                                      MM2 works on Pi0. If you want install MM2 on Pi0 use the @evos process or use my install file.
                                      N 2 Replies Last reply Reply Quote 1
                                      • N
                                        nigel-daniels @Neokamikaze
                                        @Neokamikaze thanks, I’d manually got to the same sort of place the script would have got me to… It would have got me there faster ;) Further testing has shown it was my set up of kweb that was at fault not MM2 (the page loaded correctly with firefox). I was testing the page in regular browser mode before using kiosk mode so I can perfect my own config.sh. It turned out I had jScript and cookies off, with these enabled fixed the issue I was seeing.
                                        Thanks for all your great work on getting MM2 working on the Pi0!
                                        • N
                                          nigel-daniels @KirAsh4
                                          @KirAsh4 it may be worth getting the support statement updated to the same level as using the Pi1, the Pi0 will run MM2 quite happily using ‘node serveronly’… in my case it turn out you just need to be sure kweb is set up correctly if that is the browser of choice ;)
                                            darkeagl105
                                            I can confirm. It is working with pi 1 in server only mode and kweb. Just some modules don’t show like mmm-sonos. If you connect with anotrr machine with chrome it works normally so it is a browser problem :( and I couldn’t find a solution for that till now
