    Pi Zero
    pizero
    37 Posts 10 Posters 54.9k Views 12 Watching
      jfi1310
      I’ve read something about no support for the Zero. The specs are good enough I think, but is it supported by the software?
      I already have a Zero and a wifi dongle, so it would definetely be cheaper. And less space necessary…
      MitchfarinoM 1 Reply Last reply Reply Quote 0
      • MitchfarinoM Offline
        Mitchfarino Module Developer @jfi1310
        @jfi1310 it may have been me who replied to you. As I was told the zero wasnt supported.
        I’m the same, I’ve got a WiFi adapter etc for mine
        • MichMichM Offline
          MichMich
          Well I personally never tried it, but I don’t see a reason why it shouldn’t work … :)
            jfi1310
            There’s this topic:
            https://forum.magicmirror.builders/topic/201/sudo-npm-start-does-nothing-on-a-pi-zero/12
            Is it a problem especially with the Pi Zero or just because of the card switching?
              jfi1310
              I just tried to install it on the Pi Zero but there was this message:
              No Chance?
              • MichMichM Offline
                MichMich
                Hmmm … it seems the Zero is running on ARMv6. Just like the the Pi 1. Unfortunately, Electron (the browser frame on which MagicMirror relies) does not support ARMv6. You can install MagicMirror² and just use the serveronly method, but you would need to setup a browser in kiosk mode yourself. Which is tricky on the ARMv6 platform.
                • N Offline
                  Neokamikaze
                  I modify the installation file for Pi0. But the program don’t start. My Post “npm-do-not-start”
                  and the file.
                  0_1469782479446_MagicMirrorInstallPi0.sh
                  I don’t find the solution for the moment.
                  • N Offline
                    Neokamikaze
                    Ok thanks
                    • N Offline
                      Neokamikaze
                      Now is ok for the Pi0. But just for install Kweb.
                      i use this commands:
                      wget http://steinerdatenbank.de/software/kweb-1.7.3.tar.gz
                      tar -xzf kweb-1.7.3.tar.gz
                      cd kweb-1.7.3
                      ./debinstall
                      • N Offline
                        nigel-daniels
                        I’ve just tried out running MM2 on a Pi0. It all seems to load up using the server only but when I fire up kweb I just end up with a blank screen. This was a new install so I used the basic config file and added my own data (e.g. weather app key, etc.). I’m new to using MM2 as well so I was not sure if I should be seeing lines like:
                        No helper found for module: nnnn
                        As far as I can tell the calendar and newsfeed have started, but nothing is displayed :(
                        Any recommendations on the diagnostic steps I need to take?
                        • 1 / 4
