    Pi Zero
    pizero
    37 Posts 10 Posters 54.9k Views 12 Watching
    • MitchfarinoM Offline
      Mitchfarino Module Developer @jfi1310
      @jfi1310 it may have been me who replied to you. As I was told the zero wasnt supported.
      I’m the same, I’ve got a WiFi adapter etc for mine
      • MichMichM Offline
        MichMich
        Well I personally never tried it, but I don’t see a reason why it shouldn’t work … :)
          jfi1310
          There’s this topic:
          https://forum.magicmirror.builders/topic/201/sudo-npm-start-does-nothing-on-a-pi-zero/12
          Is it a problem especially with the Pi Zero or just because of the card switching?
            jfi1310
            I just tried to install it on the Pi Zero but there was this message:
            No Chance?
            • MichMichM Offline
              MichMich
              Hmmm … it seems the Zero is running on ARMv6. Just like the the Pi 1. Unfortunately, Electron (the browser frame on which MagicMirror relies) does not support ARMv6. You can install MagicMirror² and just use the serveronly method, but you would need to setup a browser in kiosk mode yourself. Which is tricky on the ARMv6 platform.
              • N Offline
                Neokamikaze
                I modify the installation file for Pi0. But the program don’t start. My Post “npm-do-not-start”
                and the file.
                0_1469782479446_MagicMirrorInstallPi0.sh
                I don’t find the solution for the moment.
                • N Offline
                  Neokamikaze
                  Ok thanks
                  • N Offline
                    Neokamikaze
                    Now is ok for the Pi0. But just for install Kweb.
                    i use this commands:
                    wget http://steinerdatenbank.de/software/kweb-1.7.3.tar.gz
                    tar -xzf kweb-1.7.3.tar.gz
                    cd kweb-1.7.3
                    ./debinstall
                    • N Offline
                      nigel-daniels
                      I’ve just tried out running MM2 on a Pi0. It all seems to load up using the server only but when I fire up kweb I just end up with a blank screen. This was a new install so I used the basic config file and added my own data (e.g. weather app key, etc.). I’m new to using MM2 as well so I was not sure if I should be seeing lines like:
                      No helper found for module: nnnn
                      As far as I can tell the calendar and newsfeed have started, but nothing is displayed :(
                      Any recommendations on the diagnostic steps I need to take?
                      • KirAsh4K Offline
                        KirAsh4 Moderator
                        Hopefully the community can help you out here as the Pi0 is not supported. Some people may have gotten it to work though …
                        • 1 / 4
