    Help! Probem using PIR Sensor on raspberry pi zero to turn on/off screen
    15 Posts 5 Posters 9.5k Views 5 Watching
    • randomnoiseR
      randomnoise
      Have you disabled screensaver? That can cause the screen to remain blank.
      Easiest way is to install xscreensaver then disable it from the desktop (yes this seems counterintuitive but it works)
      MikgaboM 1 Reply Last reply
      • MikgaboM
        Mikgabo @randomnoise
        @randomnoise
        Hey! Thanks for getting back to me.
        My MM works pretty well, can’t get MMM stock to work though.
        My major problem is getting my PIR sensor to function properly. I have it working properly on a pi3 but not the zero.
        What code did u use for your PIR?
        Thanks,
        Mike
        Mykle1M N 2 Replies Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Mikgabo
          @Mikgabo said in Help! Probem using PIR Sensor on raspberry pi zero to turn on/off screen:
          If I remember correctly, that module’s API is no longer working, thus, killing the module. :-(
          • MikgaboM
            Mikgabo @Mykle1
            @Mykle1 Good day!
            That’s interesting, I have MMM stock working on my Pi3. I am running an older version of Jessie though.
            For you know of any stock ticker that would work on Pi Zero?
            Thanks,
            Mike
            Mykle1M 1 Reply Last reply
            • Mykle1M
              @Mikgabo
              Obviously, I am mistaken then, and I apologize for an old man’s faulty memory. :-/
              I don’t know if this is what you are looking for or if it works
              on a Pi zero
              https://github.com/alexyak/stocks
              • MikgaboM
                Mikgabo @Mykle1
                @Mykle1 Many thanks, I’ll give it a try!
                I have a few more avenues to explore I respect to the PIR sensor and will report back if successful.
                Cheers,
                Mike
                • N
                  NoNameRo @Mikgabo
                  for the Pi Zero use the PIR script from @cruunnerr --> point 2.2 Using PIR script
                  maybe this is helpful
                  The very important thing is, that your monitor supports HDMI-CEC or ARC. Otherwise u will not be able to turn it on or off via HDMI.
                  To reassure you, most monitors do this ;)
                  To check if it works just go into terminal via ssh and type:
                  sudo tvservice -o to turn off
                  sudo tvservice -p to turn on
                  edit: for some monitors the following commands work better. Please use them if your monitor needs it:
                  vcgencmd display_power 0 to turn off
                  vcgencmd display_power 1 to turn on
                  MikgaboM 2 Replies Last reply
                  • MikgaboM
                    Mikgabo @NoNameRo
                    @NoNameRo Hi!
                    Thanks for the reply :)
                    I’ll give it a try later when the kids are sleeping.
                    Cheers,
                    Mike
                    • MikgaboM
                      Mikgabo @NoNameRo
                      @NoNameRo
                      Hi, So I placed this command sudo tvservice -o to turn offi in terminal and this is the result…any feedback?
                      pi@MagicMirror:~ $ sudo tvservice -o to turn off
                      [E] Unrecognized argument -- 'to'
                      Usage: tvservice [OPTION]...
                        -p, --preferred                   Power on HDMI with preferred settings
                        -e, --explicit="GROUP MODE DRIVE" Power on HDMI with explicit GROUP (CEA, DMT, CEA_3D_SBS, CEA_3D_TB, CEA_3D_FP, CEA_3D_FS)
                                                            MODE (see --modes) and DRIVE (HDMI, DVI)
                        -t, --ntsc                        Use NTSC frequency for HDMI mode (e.g. 59.94Hz rather than 60Hz)
                        -c, --sdtvon="MODE ASPECT [P]"    Power on SDTV with MODE (PAL or NTSC) and ASPECT (4:3 14:9 or 16:9) Add P for progressive
                        -o, --off                         Power off the display
                        -m, --modes=GROUP                 Get supported modes for GROUP (CEA, DMT)
                        -M, --monitor                     Monitor HDMI events
                        -s, --status                      Get HDMI status
                        -a, --audio                       Get supported audio information
                        -d, --dumpedid          Dump EDID information to file
                        -j, --json                        Use JSON format for --modes output
                        -n, --name                        Print the device ID from EDID
                        -h, --help                        Print this information
                      FYI this is how i’m trying to configure my PIR https://www.magicmirrorcentral.com/pir-sensor-raspberry-pi-magic-mirror/
                      If you have a soluton that currently works on your Pi ZERO please pass it on.
                      Thanks,
                      Mike
                      N 1 Reply Last reply
                      • N
                        NoNameRo @Mikgabo
                        @Mikgabo
                        To test if it works, you should enter it correctly
                        to turn off the screen
                        sudo tvservice -o
                        or
                        to turn on the screen
                        sudo tvservice -p
                        or
                        please follow the instructions under 2.2 Using PIR-Script, then your PIR will work too
                        • MikgaboM
                          Mikgabo @NoNameRo
                          @NoNameRo Thanks! I’ll give it a try.
                          • MikgaboM
                            Mikgabo @NoNameRo
                            @NoNameRo
                            Thanks SOO much!!! Got er working now. I really appreciate your help in the matter!!!
                            Cheers,
                            Mike
