    Help! Probem using PIR Sensor on raspberry pi zero to turn on/off screen
    15 Posts 5 Posters 9.5k Views 5 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Mikgabo
      @Mikgabo said in Help! Probem using PIR Sensor on raspberry pi zero to turn on/off screen:
      can’t get MMM stock to work though.
      If I remember correctly, that module’s API is no longer working, thus, killing the module. :-(
      MikgaboM 1 Reply Last reply
      • MikgaboM
        Mikgabo @Mykle1
        @Mykle1 Good day!
        That’s interesting, I have MMM stock working on my Pi3. I am running an older version of Jessie though.
        For you know of any stock ticker that would work on Pi Zero?
        Thanks,
        Mike
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @Mikgabo
          Obviously, I am mistaken then, and I apologize for an old man’s faulty memory. :-/
          I don’t know if this is what you are looking for or if it works
          on a Pi zero
          https://github.com/alexyak/stocks
          • MikgaboM
            Mikgabo @Mykle1
            @Mykle1 Many thanks, I’ll give it a try!
            I have a few more avenues to explore I respect to the PIR sensor and will report back if successful.
            Cheers,
            Mike
            • N
              NoNameRo @Mikgabo
              My major problem is getting my PIR sensor to function properly. I have it working properly on a pi3 but not the zero.
              What code did u use for your PIR?
              for the Pi Zero use the PIR script from @cruunnerr --> point 2.2 Using PIR script
              maybe this is helpful
              The very important thing is, that your monitor supports HDMI-CEC or ARC. Otherwise u will not be able to turn it on or off via HDMI.
              To reassure you, most monitors do this ;)
              To check if it works just go into terminal via ssh and type:
              sudo tvservice -o to turn off
              sudo tvservice -p to turn on
              edit: for some monitors the following commands work better. Please use them if your monitor needs it:
              vcgencmd display_power 0 to turn off
              vcgencmd display_power 1 to turn on
              MikgaboM 2 Replies Last reply
              • MikgaboM
                Mikgabo @NoNameRo
                @NoNameRo Hi!
                Thanks for the reply :)
                I’ll give it a try later when the kids are sleeping.
                Cheers,
                Mike
                • MikgaboM
                  Mikgabo @NoNameRo
                  @NoNameRo
                  Hi, So I placed this command sudo tvservice -o to turn offi in terminal and this is the result…any feedback?
                  pi@MagicMirror:~ $ sudo tvservice -o to turn off
                  [E] Unrecognized argument -- 'to'
                  Usage: tvservice [OPTION]...
                    -p, --preferred                   Power on HDMI with preferred settings
                    -e, --explicit="GROUP MODE DRIVE" Power on HDMI with explicit GROUP (CEA, DMT, CEA_3D_SBS, CEA_3D_TB, CEA_3D_FP, CEA_3D_FS)
                                                        MODE (see --modes) and DRIVE (HDMI, DVI)
                    -t, --ntsc                        Use NTSC frequency for HDMI mode (e.g. 59.94Hz rather than 60Hz)
                    -c, --sdtvon="MODE ASPECT [P]"    Power on SDTV with MODE (PAL or NTSC) and ASPECT (4:3 14:9 or 16:9) Add P for progressive
                    -o, --off                         Power off the display
                    -m, --modes=GROUP                 Get supported modes for GROUP (CEA, DMT)
                    -M, --monitor                     Monitor HDMI events
                    -s, --status                      Get HDMI status
                    -a, --audio                       Get supported audio information
                    -d, --dumpedid          Dump EDID information to file
                    -j, --json                        Use JSON format for --modes output
                    -n, --name                        Print the device ID from EDID
                    -h, --help                        Print this information
                  FYI this is how i’m trying to configure my PIR https://www.magicmirrorcentral.com/pir-sensor-raspberry-pi-magic-mirror/
                  If you have a soluton that currently works on your Pi ZERO please pass it on.
                  Thanks,
                  Mike
                  N 1 Reply Last reply
                  • N
                    NoNameRo @Mikgabo
                    @Mikgabo
                    To test if it works, you should enter it correctly
                    to turn off the screen
                    sudo tvservice -o
                    or
                    to turn on the screen
                    sudo tvservice -p
                    or
                    please follow the instructions under 2.2 Using PIR-Script, then your PIR will work too
                    • MikgaboM
                      Mikgabo @NoNameRo
                      @NoNameRo Thanks! I’ll give it a try.
                      • MikgaboM
                        Mikgabo @NoNameRo
                        @NoNameRo
                        Thanks SOO much!!! Got er working now. I really appreciate your help in the matter!!!
                        Cheers,
                        Mike
