    Help! Probem using PIR Sensor on raspberry pi zero to turn on/off screen
    15 Posts 5 Posters 9.2k Views 5 Watching
      Petal0u @Petal0u
      Pir sensor module works fine. Screen wakes up.
      I stil have nothing on screen, no smart mirror.
      MikgaboM 1 Reply Last reply Reply Quote 0
      • MikgaboM Offline
        Mikgabo @Petal0u
        @Petal0u did u ever get to solve the problem? I’m currently in the same boat.
        Cheers,
        Mike
        • randomnoiseR Offline
          randomnoise
          Have you disabled screensaver? That can cause the screen to remain blank.
          Easiest way is to install xscreensaver then disable it from the desktop (yes this seems counterintuitive but it works)
          • MikgaboM Offline
            Mikgabo @randomnoise
            @randomnoise
            Hey! Thanks for getting back to me.
            My MM works pretty well, can’t get MMM stock to work though.
            My major problem is getting my PIR sensor to function properly. I have it working properly on a pi3 but not the zero.
            What code did u use for your PIR?
            Thanks,
            Mike
            Mykle1M N 2 Replies Last reply Reply Quote 0
              Mykle1 Project Sponsor Module Developer @Mikgabo
              @Mikgabo said in Help! Probem using PIR Sensor on raspberry pi zero to turn on/off screen:
              If I remember correctly, that module’s API is no longer working, thus, killing the module. :-(
              • MikgaboM Offline
                Mikgabo @Mykle1
                @Mykle1 Good day!
                That’s interesting, I have MMM stock working on my Pi3. I am running an older version of Jessie though.
                For you know of any stock ticker that would work on Pi Zero?
                Thanks,
                Mike
                  @Mikgabo
                  Obviously, I am mistaken then, and I apologize for an old man’s faulty memory. :-/
                  I don’t know if this is what you are looking for or if it works
                  on a Pi zero
                  https://github.com/alexyak/stocks
                  • MikgaboM Offline
                    Mikgabo @Mykle1
                    @Mykle1 Many thanks, I’ll give it a try!
                    I have a few more avenues to explore I respect to the PIR sensor and will report back if successful.
                    Cheers,
                    Mike
                    • N Offline
                      NoNameRo @Mikgabo
                      for the Pi Zero use the PIR script from @cruunnerr --> point 2.2 Using PIR script
                      maybe this is helpful
                      The very important thing is, that your monitor supports HDMI-CEC or ARC. Otherwise u will not be able to turn it on or off via HDMI.
                      To reassure you, most monitors do this ;)
                      To check if it works just go into terminal via ssh and type:
                      sudo tvservice -o to turn off
                      sudo tvservice -p to turn on
                      edit: for some monitors the following commands work better. Please use them if your monitor needs it:
                      vcgencmd display_power 0 to turn off
                      vcgencmd display_power 1 to turn on
                      MikgaboM 2 Replies Last reply Reply Quote 0
                      • MikgaboM Offline
                        Mikgabo @NoNameRo
                        @NoNameRo Hi!
                        Thanks for the reply :)
                        I’ll give it a try later when the kids are sleeping.
                        Cheers,
                        Mike
                        • MikgaboM Offline
                          Mikgabo @NoNameRo
                          @NoNameRo
                          Hi, So I placed this command sudo tvservice -o to turn offi in terminal and this is the result…any feedback?
                          pi@MagicMirror:~ $ sudo tvservice -o to turn off
                          [E] Unrecognized argument -- 'to'
                          Usage: tvservice [OPTION]...
                            -p, --preferred                   Power on HDMI with preferred settings
                            -e, --explicit="GROUP MODE DRIVE" Power on HDMI with explicit GROUP (CEA, DMT, CEA_3D_SBS, CEA_3D_TB, CEA_3D_FP, CEA_3D_FS)
        MODE (see --modes) and DRIVE (HDMI, DVI)
                            -t, --ntsc                        Use NTSC frequency for HDMI mode (e.g. 59.94Hz rather than 60Hz)
                            -c, --sdtvon="MODE ASPECT [P]"    Power on SDTV with MODE (PAL or NTSC) and ASPECT (4:3 14:9 or 16:9) Add P for progressive
                            -o, --off                         Power off the display
                            -m, --modes=GROUP                 Get supported modes for GROUP (CEA, DMT)
                            -M, --monitor                     Monitor HDMI events
                            -s, --status                      Get HDMI status
                            -a, --audio                       Get supported audio information
                            -d, --dumpedid          Dump EDID information to file
                            -j, --json                        Use JSON format for --modes output
                            -n, --name                        Print the device ID from EDID
                            -h, --help                        Print this information
                          FYI this is how i’m trying to configure my PIR https://www.magicmirrorcentral.com/pir-sensor-raspberry-pi-magic-mirror/
                          If you have a soluton that currently works on your Pi ZERO please pass it on.
                          Thanks,
                          Mike
                          • N Offline
                            NoNameRo @Mikgabo
                            @Mikgabo
                            To test if it works, you should enter it correctly
                            to turn off the screen
                            sudo tvservice -o
                            or
                            to turn on the screen
                            sudo tvservice -p
                            or
                            please follow the instructions under 2.2 Using PIR-Script, then your PIR will work too
                            • MikgaboM Offline
                              Mikgabo @NoNameRo
                              @NoNameRo Thanks! I’ll give it a try.
                              • MikgaboM Offline
                                Mikgabo @NoNameRo
                                @NoNameRo
                                Thanks SOO much!!! Got er working now. I really appreciate your help in the matter!!!
                                Cheers,
                                Mike
