Raspbian on Apple hardware - can't install MM because it's "not a Pi 2/3"
@bnsrx did you git clone and npm install afterwards or did you try the automatic installation via curl?
I did the curl install. Think I’ll have better luck on the git clone?
@bnsrx I think it’s worth a try, yes
Thanks. Here’s a question though… having installed node.js on my Pixel Mac, I can’t just type “npm install && npm start” - npm isn’t recognised. If I type node -v it doesn’t recognise that, or npm -v - but it does recognise nodejs -v.
If I type nodejs and enter that…app?, and I then type npm install && npm start, I get the response “npm should be run outside of your node repl, in your normal shell”.
Any thoughts much appreciated.
@yawns …update,
downloaded installers/raspberry.sh, removed the lines in which the script sniffs your pi, saved it to my dropbox and ran it from there. Installing now, will update if successful.
update: unsuccessful. Was going great until it hit the same problem - “npm - command not found. Unable to install dependencies.”
I wonder why npm is not flying on this port of Pixel.
