    MM modules not displaying or no longer refresh after restart
    7 Posts 3 Posters 2.5k Views 2 Watching
      A Former User
      Hi All
      Need to request some help if I may. It seems my MM has stopped functioning and I can’t
      figure out why, rather frustratingly.
      Started yesterday after some seemingly innocuous changes I made to config.js (adding MMM-random quote which has now been removed)
      Issues as follows:
      • Default clock displays but does not refresh beyond restart
      • Default weather forecast does not display
      • Calendar monthly displays intermittently on refresh or remains “Loading…”
      • Default news feed does not display
      Pasting config.js
       * MIT Licensed.
      var config = {
              port: 8080,
              language: "en",
              timeFormat: 24,
              units: "metric",
                              module: "alert",
                              module: "updatenotification",
                              position: "top_bar"
                              module: "clock",
                              position: "top_left"
                              header: "UK Holidays",
                              position: "bottom_left",
                                                      symbol: "calendar-check-o ",
                                                      url: "webcal://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"
                             module: "currentweather",
                                      locationID: "2643741",  //ID from http://www.openweathermap.org/help/city_list.txt
                                      appid: "[redacted]"
                              module: "weatherforecast",
                              header: "Weather Forecast",
                                      appid: "[redacted]"
                              module: "compliments",
                                      updateInterval: 5000,
                                      fadeSpeed: 1000,
                                      compliments: {
                                              day_sunny: [
                                                      "Today is a sunny day",
                                                      "It's a beautiful day"
                                              snow: [
                                                      "Snowball battle!"
                                              rain: [
                                                      "Don't forget your umbrella"
                                              showers: [
                                                      "Looks like it might rain!"
                              module: "newsfeed",
                              position: "bottom_bar",
                                      feeds: [
                                                      title: "BBC World News",
                                                      url: "http://feeds.bbci.co.uk/news/world/rss.xml"
                                      showSourceTitle: true,
                                      showPublishDate: true
                              module: "MMM-Globe",
                              position: "bottom_right",
                                      style: "europeDiscNat",
                                      imageSize: 300,
                                      ownImagePath:'',
                                      updateInterval: 10*60*1000
                                      module: "calendar_monthly",
                                                      // The config property is optional
                                                      // Without a config, a default month view is shown
                                                      // Please see the 'Configuration Options' section for more information
      I have run npm run config:check and confirm that there are no syntax errors (presumably would’ve seen black screen otherwise)
      I have also run pm2 info MagicMirror and get the following output which I believe shows no obvious issues;
      Describing process with id 0 - name MagicMirror
      │ status            │ online                                     │
      │ name              │ MagicMirror                                │
      │ restarts          │ 0                                          │
      │ uptime            │ 19m                                        │
      │ script path       │ /home/pi/MagicMirror/installers/mm.sh      │
      │ script args       │ N/A                                        │
      │ error log path    │ /home/pi/.pm2/logs/MagicMirror-error-0.log │
      │ out log path      │ /home/pi/.pm2/logs/MagicMirror-out-0.log   │
      │ pid path          │ /home/pi/.pm2/pids/MagicMirror-0.pid       │
      │ interpreter       │ bash                                       │
      │ interpreter args  │ N/A                                        │
      │ script id         │ 0                                          │
      │ exec cwd          │ /home/pi/MagicMirror                       │
      │ exec mode         │ fork_mode                                  │
      │ node.js version   │ N/A                                        │
      │ watch & reload    │ ✔                                          │
      │ unstable restarts │ 0                                          │
      │ created at        │ 2018-04-24T21:19:54.160Z                   │
       Revision control metadata
      │ revision control │ git                                                       │
      │ remote url       │ https://github.com/MichMich/MagicMirror.git               │
      │ repository root  │ /home/pi/MagicMirror                                      │
      │ last update      │ 2018-04-25T07:01:33.788Z                                  │
      │ revision         │ 60b9a5b9dad36a7748a5d1bdb3b32c0c6384e4c0                  │
      │ comment          │ Merge pull request #1245 from MichMich/electron-downgrade │
      │ branch           │ master                                                    │
      Really at a loss as to what the problem is and considered entire reinstallation.
      Any help would be greatly appreciated so please let me know if more info is required.
        Charley Module Developer
        Did you enter the proper module name for the calendar?
        Try to comment calendar out to see if it works without.
        MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
          A Former User @Charley
          @Charley
          Thanks for the suggestion.
          1. Which calendar do you mean? There’s default (bottom left) and there’s calendar-monthly (top left).
          2. when you say comment out, do you mean the name or the entire module?
            I would say calendar monthly
            Every line from the first { until the last }
            Just type // before if it runs that points to the module That holds the rest.
              @Charley
              Thanks for the suggestions.
              Bizarrely I didn’t need to do anything, just left pi off for a few days whilst I worked on some other projects.
              Switched on this afternoon and everything is perfect again.
              Weird
                bhepler Module Developer @Guest
                @lodown It sounds like you had a temporary network interruption. Everything that you listed as a problem requires a network pull to update. Except the clock, which is just weird. Even the time synchronization failing due to a network interruption shouldn’t affect the clock.
                  A Former User @bhepler
                  @bhepler
                  Got it! I did wonder whether that might be it but the outages were so ridiculously coincidental with the changes I was making that I had to wonder whether I had broken something.
                  Happy to report that everything is still working as expected at this time.
                  Thanks all for the suggestions.
