MM modules not displaying or no longer refresh after restart
7 Posts 3 Posters 2.2k Views 2 Watching
    A Former User @Charley
    @Charley
    Thanks for the suggestion.
    1. Which calendar do you mean? There’s default (bottom left) and there’s calendar-monthly (top left).
    2. when you say comment out, do you mean the name or the entire module?
      Charley Module Developer
      I would say calendar monthly
      Every line from the first { until the last }
      Just type // before if it runs that points to the module That holds the rest.
      MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
      ? 1 Reply Last reply Apr 27, 2018, 5:37 PM Reply Quote 0
        @Charley
        Thanks for the suggestions.
        Bizarrely I didn’t need to do anything, just left pi off for a few days whilst I worked on some other projects.
        Switched on this afternoon and everything is perfect again.
        Weird
        B 1 Reply Last reply Apr 27, 2018, 6:43 PM Reply Quote 0
          bhepler Module Developer @Guest
          @lodown It sounds like you had a temporary network interruption. Everything that you listed as a problem requires a network pull to update. Except the clock, which is just weird. Even the time synchronization failing due to a network interruption shouldn’t affect the clock.
          ? 1 Reply Last reply Apr 30, 2018, 11:14 AM Reply Quote 0
            A Former User @bhepler
            @bhepler
            Got it! I did wonder whether that might be it but the outages were so ridiculously coincidental with the changes I was making that I had to wonder whether I had broken something.
            Happy to report that everything is still working as expected at this time.
            Thanks all for the suggestions.
