    Debugging
    22 Posts 7 Posters 22.8k Views 6 Watching
    • E
      Eunanibus Module Developer
      Sorry to keep on this. Is there a particular way I’m able to look at a particular object’s available functions in console (if there is a way, I can’t see it and google is turning up zilch)
      • K
        KirAsh4 Moderator
        I suspect the answer is: go read the source code … but, what are you trying to do?
        • E
          It’s my source code :laughing: - My object should have an available function to me, but it’s coming up function not found. I’m gonna keep digging! New module is on its way.
          • K
            KirAsh4 Moderator
            Theeeeen you’re not defining it as a function … ?
            • A
              alexyak
              You don’t have to run the the code in the electron every time. I would just run “node index” from the /serveronly folder and start the chrome with dev tools on my dev box. Also as dev tool Visual Studio Code is a very good one and runs on Windows, Linux and OS X. You could configure it to debug the node.js as well as the chrome client (via a plugin) locally or even have a remote debugging session.
                bobbob601
                  BenRoe Module Developer
                  I could not use Log.log('foobar'); in the node_helper.js and if i use console.log('foobar'); the log is shown in the CLI. Is there a solution to show it in the Browser Console?
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @BenRoe
                    @BenRoe quote from the readme The Magic Mirror contains a convenience wrapper for logging. Currently, this logger is a simple proxy to the original console.log methods. But it might get additional features in the future. The Loggers is currently only available in the core module file (not in the node_helper). so everything you have experinced is as it should be
                    instead of logging in the node_helper directly you could send the string, objects, etc. to your module and use the logger there to view it in the browsers console
                      Sputnik @strawberry 3.141
                      @strawberry-3.141 I got the following error when I run pm2 log mm:
                      error: cannot open .git/FETCH_HEAD: Permission denied
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @Sputnik
                        @Sputnik could be the updatenotification module, which is probably not able to read a modules git config. Did you download modules manually or did you use git clone?
