    Debugging
    22 Posts 7 Posters 22.8k Views 6 Watching
    • K
      KirAsh4 Moderator
      Nothing would appear in the terminal, it’s not the STDOUT facility that you’re using. The console.log() facility logs to the browser’s console log. With most browsers, you access this by pressing F12. This is what my desktop looks like when I’m coding. Note that this is a Windows machine with dual monitors. On the left monitor is my code editor, split into two panels so I can look at multiple files at the same time. The files are being opened directly from the MagicMirror folder on the Raspberry Pi. On the right is a Chrome browser open with the Raspberry Pi’s IP address. That loads up the mirror display. And by hitting F12, I get the console panel that you see open, and at the bottom you can see the debugging messages that I put in the code to track. I can write/change code in the editor, hit Save, then hit Refresh in Chrome and get instant feedback. All of that is completely independent of what’s actually being displayed on the Raspberri Pi’s monitor.
      The panel also allows me to see the actual HTML being returned (by selecting Elements at the top.) So any code that I write, I can verify the HTML bit, and I can follow along with any errors or other messages that I put in the code. When the mirror code fails for some reason, I can look in the console and try to figure out where the error lies.
      • E
        Eunanibus Module Developer
        Your last post helped immensely! Thank you!
        • E
          Sorry to keep on this. Is there a particular way I’m able to look at a particular object’s available functions in console (if there is a way, I can’t see it and google is turning up zilch)
          • K
            KirAsh4 Moderator
            I suspect the answer is: go read the source code … but, what are you trying to do?
            • E
              It’s my source code :laughing: - My object should have an available function to me, but it’s coming up function not found. I’m gonna keep digging! New module is on its way.
              • K
                KirAsh4 Moderator
                Theeeeen you’re not defining it as a function … ?
                • A
                  alexyak
                  You don’t have to run the the code in the electron every time. I would just run “node index” from the /serveronly folder and start the chrome with dev tools on my dev box. Also as dev tool Visual Studio Code is a very good one and runs on Windows, Linux and OS X. You could configure it to debug the node.js as well as the chrome client (via a plugin) locally or even have a remote debugging session.
                    bobbob601
                      BenRoe Module Developer
                      I could not use Log.log('foobar'); in the node_helper.js and if i use console.log('foobar'); the log is shown in the CLI. Is there a solution to show it in the Browser Console?
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @BenRoe
                        @BenRoe quote from the readme The Magic Mirror contains a convenience wrapper for logging. Currently, this logger is a simple proxy to the original console.log methods. But it might get additional features in the future. The Loggers is currently only available in the core module file (not in the node_helper). so everything you have experinced is as it should be
                        instead of logging in the node_helper directly you could send the string, objects, etc. to your module and use the logger there to view it in the browsers console
                          Sputnik @strawberry 3.141
                          @strawberry-3.141 I got the following error when I run pm2 log mm:
                          error: cannot open .git/FETCH_HEAD: Permission denied
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @Sputnik
                            @Sputnik could be the updatenotification module, which is probably not able to read a modules git config. Did you download modules manually or did you use git clone?
