    MagicMirror wont start
    6 Posts 4 Posters 2.7k Views 3 Watching
    • K Offline
      kalleK
      hello
      i have a problem. the magicmirror installation was succesfull and i tried a few things. ive made a break and now i thougt i can continue my work. but when i type npm start in MagicMirror folder i get this errorcode
      > magicmirror@2.3.1 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.3.1
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-Remote-Control-Repository
      Module helper loaded: MMM-TelegramBot
      Module helper loaded: MMM-PIR-Sensor
      Module helper loaded: MMM-Todoist
      All module helpers loaded.
      You're using a full whitelist configuration to allow for all IPs
      Server started ...
      Starting module: newsfeed
      Connecting socket for: MMM-Remote-Control-Repository
      Starting node helper for: MMM-Remote-Control
      Connecting socket for: MMM-TelegramBot
      Connecting socket for: MMM-PIR-Sensor
      Connecting socket for: MMM-Todoist
      Starting node helper for: MMM-Todoist
      { Error: listen EADDRINUSE 127.0.0.1:8080
          at Object.exports._errnoException (util.js:1050:11)
          at exports._exceptionWithHostPort (util.js:1073:20)
          at Server.setupListenHandle [as _listen2] (net.js:1263:14)
          at listenInCluster (net.js:1304:12)
          at doListen (net.js:1428:7)
          at GetAddrInfoReqWrap.asyncCallback [as callback] (dns.js:62:16)
          at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:78:10)
        code: 'EADDRINUSE',
        errno: 'EADDRINUSE',
        syscall: 'listen',
        address: '127.0.0.1',
        port: 8080 }
      Launching application.
      (node:7234) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): TypeError: Cannot read property 'refs' of undefined
      (node:7234) DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      (node:7234) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): TypeError: Cannot read property 'refs' of undefined
      (node:7234) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3): TypeError: Cannot read property 'refs' of undefined
      (node:7234) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 4): TypeError: Cannot read property 'refs' of undefined
      (node:7234) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 5): TypeError: Cannot read property 'refs' of undefined
      (node:7234) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 6): TypeError: Cannot read property 'refs' of undefined
      (node:7234) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 7): TypeError: Cannot read property 'refs' of undefined
      i hope you can help me. sorry for my bad english
      idoodlerI 1 Reply Last reply Reply Quote 0
      • Y Offline
        yawns Moderator
        That means there is another process running on port 8080. Did you maybe install pm2 to automate startup? Check with pm2 list
        • idoodlerI Offline
          idoodler Module Developer @kalleK
          @kalleK This looks like you already have an instance of MagicMirror running. Do you use pm2 to run your MagicMirror on startup?
          If you use pm2 you can run pm2 restart MagicMirror to restart the MagicMirror.
          • K Offline
            kalleK
            Thank you for your reply. You are right. Nevertheless is there another Error :
            What means this ?
            • K Offline
              kalleK
              this is the reply now:
              > sh run-start.sh
              Loading config ...
              Server started ...
              (node:19302) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): TypeError: Cannot read property 'refs' of undefined
              (node:19302) DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
              (node:19302) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): TypeError: Cannot read property 'refs' of undefined
              (node:19302) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3): TypeError: Cannot read property 'refs' of undefined
              (node:19302) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 4): TypeError: Cannot read property 'refs' of undefined
              (node:19302) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 5): TypeError: Cannot read property 'refs' of undefined
              (node:19302) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 6): TypeError: Cannot read property 'refs' of undefined
              (node:19302) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 7): TypeError: Cannot read property 'refs' of undefined
              Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/m9e75p8rl08l641vc5cm4bhrtg%40group.calendar.google.com/public/basic.ics - Interval: 300000
              Create new calendar fetcher for url: http://www.schwarze-elster.de/touren/getICalendar.php?reminder=0&ort=1&from=1.4.2018&to=31.12.2018&tonnen=12354 - Interval: 300000
              Create new news fetcher for url: http://www.spiegel.de/schlagzeilen/tops/index.rss - Interval: 300000
              [RCREPO] Repository scanning...
              [RCREPO] modules.json is updated.
                bhepler Module Developer @kalleK
                @kalleK Well, those errors didn’t seem to kill your mirror. I would comment out the 3rd-party modules in your config.js and restart your mirror process. Add them back one at a time until you get those warnings again and then talk to the module developer. Assuming those are module errors.
