    Fitbit
    129 Posts 42 Posters 224.4k Views 37 Watching
    • O
      olliewarren411
      Hi Hellangle1978,
      Try the below I saw a few errors in the example code;
      	module: ‘MMM-fitbit’,
      	position: ‘top_center’,
      		credentials: {
      			client_id: '123456789',
      			client_secret: '123456789',
      		resources: [
      			‘steps’,
      			‘floors’,
      			‘caloriesOut’,
      			‘distance’,
      			‘activeMinutes’,
      			‘sleep’,
      			‘heart’
      • H
        Hellangel1987
        Hi @olliewarren411
        i used your code - not working.
        I created as followed in instructions an token.ini worked all out no problem.
        Just wen pasting the code in my config.js then after that the mirror will not start. Even if i use sudo npm start on desktop.
        Mirror is aways asking for an config or an error in my config after pasting that in config :(
        • O
          olliewarren411 @Hellangel1987
          @Hellangel1987 Can you post the config code you’re using please?
          • H
            Hellangel1987
            Im using your code as provided
            • O
              @Hellangel1987
              Yes If possible please paste your entire config file as the error might be elsewhere
              • H
                Hellangel1987 @olliewarren411
                @olliewarren411
                here we go
                /* Magic Mirror Config Sample
                 * MIT Licensed.
                var config = {
                	port: 8080,
                	language: 'de',
                	timeFormat: 24,
                	units: 'metric',
                        		module: 'MMM-FRITZ-Box-Callmonitor',
                        		position: 'top_right',  // This can be any of the regions. Best results in left or right regions.
                        		header: "Letzte Anrufe", // This is optional
                				credentials: {
                				client_id: ‘123456789’,
                				client_secret: ‘123456789’,
                				resources: [
                				‘steps’,
                				‘floors’,
                				‘caloriesOut’,
                				‘distance’,
                				‘activeMinutes’,
                				‘sleep’,
                				‘heart’
                			module: 'alert',
                			module: 'clock',
                			position: 'top_left'
                			module: 'calendar',
                			header: 'Feiertage',
                			position: 'top_left',
                						symbol: 'calendar-check-o ',
                						url: 'webcal://www.schulferien.org/media/ical/deutschland/ferien_bayern_2016.ics'
                			module: 'calendar',
                			header: 'Termine NetApp',
                						url: '################################'
                  			module: 'localtransport',
                			header: 'Verbindungen NBG HBF',
                    			api_key: '###########',
                    			origin: 'Nuremberg Dunantstr',
                    			destination: 'Nuremberg HBF'
                    			module: 'MMM-Traffic',
                    			header: 'Verkehr',
                    			classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
                        		api_key: '#############',
                        		mode: 'driving',
                        		origin: 'Nuernberg',
                        		destination: 'Muenchen',
                             		route_name: 'Route nach NetApp Muc',
                			show_summary: true,
                        		changeColor: true,
                        		showGreen: true,
                        		limitYellow: 5, //Greater than 5% of journey time due to traffic
                        		limitRed: 20, //Greater than 20% of journey time due to traffic
                        		traffic_model: 'best_guess',
                        		interval: 120000 //2 minutes
                			module: 'compliments',
                			position: 'lower_third'
                			module: 'currentweather',
                				locationID: '',  //ID from http://www.openweathermap.org
                				appid: '#################'
                			module: 'weatherforecast',
                			header: 'Wettervorhersage',
                				locationID: '2861650',  //ID from http://www.openweathermap.org
                	            		appid: '##############'
                    			module: 'MMM-MovieInfo',
                        		module: 'email',
                            		position: 'bottom_bar',
                            		header: 'Emails',
                            		config:{
                                	user: '##############',
                                	password: '#############',
                                	host: 'imap.mail.me.com',
                                	port: 993,
                                	tls: true,
                                	authTimeout: 10000,
                                	numberOfEmails: 5,
                                	fade: true
                			module: 'newsfeed',
                				feeds: [
                						title: "Focus Eilmeldungen",
                						url: "http://rss.focus.de/fol/XML/rss_folnews_eilmeldungen.xml"
                				showSourceTitle: true,
                				showPublishDate: true
                • O
                  @Hellangel1987
                  Looks like you’re using the wrong quote marks around elements, you’re using ‘ try using ’
                  There is a difference.
                  or use the code below; I’ve tested it working.
                  @Hellangel1987
                  or use the code attached; I’ve tested it working.
                  0_1471976763018_config.txt
                    plumcraft
                    Thanks for publishing this module but i got some issues with it.
                    When i’m running sudo python setupAccess.py and put my client and secret it, the script looks frozen. (Same behaviour after multiple retries)
                    Anyone having the same issue ?
                    I don’t know why, i’ve followed instructions here :
                    https://github.com/SVendittelli/MMM-fitbit
                    • H
                      @olliewarren411
                      good job buddy now it works but i dont get any numbers :(
                      alt text
                      • O
                        @Hellangel1987
                        No Problem.
                        When you run #sudo python setupAccess.py# on the python directory inside the MMM-fitbit folder does it redirect you to log into you fitbit account in an internet browser?
                        Also what fitbit model are you using? I tried this with a fitbit alta and it didn’t work. Then I tried with my fitbit ChargeHR and it works perfect* see attached. I changed the CSS to display vertically.
                        *i say it works perfect i just need a way to keep the connection to my fitbit account over a long period of time without having to re-run sudo python setupAccess.py on the python directory once a day.
                        H T 2 Replies Last reply Reply Quote 0
                        • H
                          @olliewarren411
                          Im using The Fitbit Charge HR
                          • O
                            @Hellangel1987
                            • H
                              Hellangel1987
                              @olliewarren411
                              yepp works perfect. i have the token and autorized that app in browser.
                              after that i startet mirror with sudo npm start. but only zero numbers are shown :(
                              Did i have to do this once a day? Any cronjob for that ?
                              • O
                                @Hellangel1987
                                Sorry I’m out of ideas then.
                                Cronjob? I’m pretty new to this.
                                • H
                                  Hellangel1987
                                  @olliewarren411 can you describe your steps and your configs ? i think there is any missconfiguration in my credentials config i think soo.
                                  • O
                                    @Hellangel1987
                                    I cant easily explain as I had to play around a lot to get it to work… and then it just did.
                                    When setting up your app on the fitbit website did you get the below steps?
                                    Check browser and personal for OAuth settings
                                    Callback URL MUST BE http://127.0.0.1:8080/
                                    Give your app read & write permissions (read-only untested)
                                    I could not set the Personal and OAuth settings until I got my personal URL wrong. When the page reloaded these two extra options appeared.
                                    H 2 Replies Last reply Reply Quote 0
                                    • H
                                      @olliewarren411
                                      i set it all on that page. exeption was my location. but all other options are set.
                                      • H
                                        @olliewarren411
                                        works! i sued your code. Delete the token. set it up new - start it with sudo npm start in MagicMirror directory. -> WORKS!
                                        I think i missunterstand the fibit API page where you have some buttons tu push and autorize the app (i think i pushed them in the wrong way)…
                                        You sayed something about your token.ini -> can you explain what exactly you have to to every day? i think about an cronjob for that - good chance to solve that together!
                                        And another option is the weight of my fitbit ARIA, these data are also available - how can we bind them into the app ?
                                        • O
                                          @Hellangel1987
                                          Glad to hear you got it working.
                                          I’m just trying to get the module to refresh more often. Not sure how to go about it.
                                          You probably could get your weight data in too, you’d need to contact the creator of the module for that.
                                          • K
                                            kckndrgn @olliewarren411
                                            @olliewarren411 said in Fitbit:
                                            Yes, you can change the refresh interval. In the script MMM-fitbit.js you’ll see
                                            start: function() {
                                            		Log.info('Starting module: ' + this.name);
                                            		this.sendSocketNotification('SET CREDS',this.config.credentials)
                                            		this.sendSocketNotification('GET DATA', 'intial');
                                            		this.fadeSpeed = 500;
                                            		// Schedule update interval.
                                            		var self = this;
                                            		setInterval(function() {
                                            			self.updateData();
                                            		}, 60*60*1000);
                                            change the 60 x 60 x 1000 to an interval of your choosing. Just be careful to to refresh too often as you’ll get emails from FB telling you that you are pulling too much data. I think (and I’d have to check tonight) that I have mine set to 15 x 60 x 1000.
                                            • 2 / 7
