    Fitbit
    129 Posts 42 Posters 226.0k Views 37 Watching
    • O
      olliewarren411 @Hellangel1987
      @Hellangel1987
      Yes If possible please paste your entire config file as the error might be elsewhere
      H 1 Reply Last reply
      • H
        Hellangel1987 @olliewarren411
        @olliewarren411
        here we go
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: 'de',
        	timeFormat: 24,
        	units: 'metric',
                		module: 'MMM-FRITZ-Box-Callmonitor',
                		position: 'top_right',  // This can be any of the regions. Best results in left or right regions.
                		header: "Letzte Anrufe", // This is optional
        				module: ‘MMM-fitbit’,
        				position: ‘top_center’,
        				credentials: {
        				client_id: ‘123456789’,
        				client_secret: ‘123456789’,
        				resources: [
        				‘steps’,
        				‘floors’,
        				‘caloriesOut’,
        				‘distance’,
        				‘activeMinutes’,
        				‘sleep’,
        				‘heart’
        			module: 'alert',
        			module: 'clock',
        			position: 'top_left'
        			module: 'calendar',
        			header: 'Feiertage',
        			position: 'top_left',
        						symbol: 'calendar-check-o ',
        						url: 'webcal://www.schulferien.org/media/ical/deutschland/ferien_bayern_2016.ics'
        			module: 'calendar',
        			header: 'Termine NetApp',
        						url: '################################'
          			module: 'localtransport',
        			header: 'Verbindungen NBG HBF',
            			api_key: '###########',
            			origin: 'Nuremberg Dunantstr',
            			destination: 'Nuremberg HBF'
            			module: 'MMM-Traffic',
            			header: 'Verkehr',
            			classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
                		api_key: '#############',
                		mode: 'driving',
                		origin: 'Nuernberg',
                		destination: 'Muenchen',
                     		route_name: 'Route nach NetApp Muc',
        			show_summary: true,
                		changeColor: true,
                		showGreen: true,
                		limitYellow: 5, //Greater than 5% of journey time due to traffic
                		limitRed: 20, //Greater than 20% of journey time due to traffic
                		traffic_model: 'best_guess',
                		interval: 120000 //2 minutes
        			module: 'compliments',
        			position: 'lower_third'
        			module: 'currentweather',
        				locationID: '',  //ID from http://www.openweathermap.org
        				appid: '#################'
        			module: 'weatherforecast',
        			header: 'Wettervorhersage',
        				locationID: '2861650',  //ID from http://www.openweathermap.org
        	            		appid: '##############'
            			module: 'MMM-MovieInfo',
                		module: 'email',
                    		position: 'bottom_bar',
                    		header: 'Emails',
                    		config:{
                        	user: '##############',
                        	password: '#############',
                        	host: 'imap.mail.me.com',
                        	port: 993,
                        	tls: true,
                        	authTimeout: 10000,
                        	numberOfEmails: 5,
                        	fade: true
        			module: 'newsfeed',
        				feeds: [
        						title: "Focus Eilmeldungen",
        						url: "http://rss.focus.de/fol/XML/rss_folnews_eilmeldungen.xml"
        				showSourceTitle: true,
        				showPublishDate: true
        O 1 Reply Last reply
        • O
          @Hellangel1987
          Looks like you’re using the wrong quote marks around elements, you’re using ‘ try using ’
          There is a difference.
          or use the code below; I’ve tested it working.
          @Hellangel1987
          or use the code attached; I’ve tested it working.
          0_1471976763018_config.txt
            plumcraft
            Thanks for publishing this module but i got some issues with it.
            When i’m running sudo python setupAccess.py and put my client and secret it, the script looks frozen. (Same behaviour after multiple retries)
            Anyone having the same issue ?
            I don’t know why, i’ve followed instructions here :
            https://github.com/SVendittelli/MMM-fitbit
            • H
              @olliewarren411
              good job buddy now it works but i dont get any numbers :(
              alt text
              • O
                @Hellangel1987
                No Problem.
                When you run #sudo python setupAccess.py# on the python directory inside the MMM-fitbit folder does it redirect you to log into you fitbit account in an internet browser?
                Also what fitbit model are you using? I tried this with a fitbit alta and it didn’t work. Then I tried with my fitbit ChargeHR and it works perfect* see attached. I changed the CSS to display vertically.
                *i say it works perfect i just need a way to keep the connection to my fitbit account over a long period of time without having to re-run sudo python setupAccess.py on the python directory once a day.
                H T 2 Replies Last reply
                • H
                  @olliewarren411
                  Im using The Fitbit Charge HR
                  • O
                    @Hellangel1987
                    • H
                      Hellangel1987
                      @olliewarren411
                      yepp works perfect. i have the token and autorized that app in browser.
                      after that i startet mirror with sudo npm start. but only zero numbers are shown :(
                      Did i have to do this once a day? Any cronjob for that ?
                      • O
                        @Hellangel1987
                        Sorry I’m out of ideas then.
                        Cronjob? I’m pretty new to this.
                        • H
                          Hellangel1987
                          @olliewarren411 can you describe your steps and your configs ? i think there is any missconfiguration in my credentials config i think soo.
                          • O
                            @Hellangel1987
                            I cant easily explain as I had to play around a lot to get it to work… and then it just did.
                            When setting up your app on the fitbit website did you get the below steps?
                            Check browser and personal for OAuth settings
                            Callback URL MUST BE http://127.0.0.1:8080/
                            Give your app read & write permissions (read-only untested)
                            I could not set the Personal and OAuth settings until I got my personal URL wrong. When the page reloaded these two extra options appeared.
                            H 2 Replies Last reply
                            • H
                              @olliewarren411
                              i set it all on that page. exeption was my location. but all other options are set.
                              • H
                                @olliewarren411
                                works! i sued your code. Delete the token. set it up new - start it with sudo npm start in MagicMirror directory. -> WORKS!
                                I think i missunterstand the fibit API page where you have some buttons tu push and autorize the app (i think i pushed them in the wrong way)…
                                You sayed something about your token.ini -> can you explain what exactly you have to to every day? i think about an cronjob for that - good chance to solve that together!
                                And another option is the weight of my fitbit ARIA, these data are also available - how can we bind them into the app ?
                                • O
                                  @Hellangel1987
                                  Glad to hear you got it working.
                                  I’m just trying to get the module to refresh more often. Not sure how to go about it.
                                  You probably could get your weight data in too, you’d need to contact the creator of the module for that.
                                  K 1 Reply Last reply
                                  • K
                                    kckndrgn @olliewarren411
                                    @olliewarren411 said in Fitbit:
                                    Yes, you can change the refresh interval. In the script MMM-fitbit.js you’ll see
                                    start: function() {
                                    		Log.info('Starting module: ' + this.name);
                                    		this.sendSocketNotification('SET CREDS',this.config.credentials)
                                    		this.sendSocketNotification('GET DATA', 'intial');
                                    		this.fadeSpeed = 500;
                                    		// Schedule update interval.
                                    		var self = this;
                                    		setInterval(function() {
                                    			self.updateData();
                                    		}, 60*60*1000);
                                    change the 60 x 60 x 1000 to an interval of your choosing. Just be careful to to refresh too often as you’ll get emails from FB telling you that you are pulling too much data. I think (and I’d have to check tonight) that I have mine set to 15 x 60 x 1000.
                                    • O
                                      olliewarren411 @kckndrgn
                                      @kckndrgn
                                      Thanks! works perfect. I’ve copied your set up so it refreshes the data every 15 mins.
                                        plumcraft
                                        I was getting invalid redirect_uri during the setup process. (sudo python setupAccess.py)
                                        But now It’s working for me, great module !
                                        • K
                                          kckndrgn
                                          Anyway to get around having to run the setupAccess.py everyday/every other day to keep the tokens fresh?
                                          Since I have to stop the MM from running, run the script to get new token, start MM again, it gets kind of annoying. I also run my Pi w/o keyboard/mouse so when I need to refresh the tokens I have to connect them.
                                          I thought about adding a cron job to stop the MM, run the script and start MM, thoughts? Since the script leaves a browser window open, can the cron job kill it or is there a way to have the python script close the window when done?
                                          TIA
                                          • H
                                            Hellangel1987 @kckndrgn
                                            @kckndrgn
                                            dont know exactly but im also interested in your cronjob solution, can you inform us about your steps ? im tired getting every day that setupaccess working :(
                                            • 2 / 7
