    Raspberry 2 clean install showing as black screen
    8 Posts 4 Posters 2.8k Views 5 Watching
    • A
      AdamRWolarczuk
      Hi all i am buggers here i have been trying to get this working for a week was going to be a gift for my wife for mothers days but no time now , i have done many many clean installs and each time no matter what i havedone it only start with a black screen and no data on the screen at all, i have made sure that the onfig file is the sample and still no data on the screen, i have tried to access it with the ipaddress from a remote pc using port 8080 and cant see anything, i am new to this any help would be great please
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @AdamRWolarczuk
        @adamrwolarczuk said in Raspberry 2 clean install showing as black screen:
        You copied the sample, pasted it and renamed the copy to config.js?
        What is your terminal reporting?
        • A
          AdamRWolarczuk
          i did yea and i am dumb ass when it comes to ths what do you need to know from the terminal
          • A
            AdamRWolarczuk
            Starting MagicMirror: v2.3.1
            Loading config …
            Loading module helpers …
            All module helpers loaded.
            Starting server on port 8080 …
            Server started …
            Starting module: newsfeed
            Sockets connected & modules started …
            Launching application.
            • Mykle1M
              @adamrwolarczuk
              Well, it certainly shows that MM is launching and running. There are several black screen topics that you can look through. Do a forum search for black screen. Otherwise, perhaps someone else will chime in that had the same problem. I suspect that electron may be at fault or that your dependencies failed to install properly
              • A
                AdamRWolarczuk
                i just ran the auto one and it didnt error at all i did a search and tried a few things and no dice
                  there is a bug in the electron browser that causes the black screen.
                  i did
                  npm remove electron
                  npm install electron@1.7.9
                  and it works fine now…
                  someone posted another solution to issue 1243
                  A 1 Reply Last reply Reply Quote 1
                  • A
                    abetterway @sdetweil
                    @sdetweil said in Raspberry 2 clean install showing as black screen:
                    npm remove electron
                    I will have to try that. Thank you! My fix had been to install another web browser and use that. Electron’s built-in browser seemed to always show a black screen.
