    Raspberry 2 clean install showing as black screen
    8 Posts 4 Posters 2.6k Views 5 Watching
      Mykle1 Project Sponsor Module Developer @AdamRWolarczuk
      @adamrwolarczuk said in Raspberry 2 clean install showing as black screen:
      i have made sure that the onfig file is the sample
      You copied the sample, pasted it and renamed the copy to config.js?
      What is your terminal reporting?
        AdamRWolarczuk
        i did yea and i am dumb ass when it comes to ths what do you need to know from the terminal
          AdamRWolarczuk
          Starting MagicMirror: v2.3.1
          Loading config …
          Loading module helpers …
          All module helpers loaded.
          Starting server on port 8080 …
          Server started …
          Starting module: newsfeed
          Sockets connected & modules started …
          Launching application.
            @adamrwolarczuk
            Well, it certainly shows that MM is launching and running. There are several black screen topics that you can look through. Do a forum search for black screen. Otherwise, perhaps someone else will chime in that had the same problem. I suspect that electron may be at fault or that your dependencies failed to install properly
              AdamRWolarczuk
              i just ran the auto one and it didnt error at all i did a search and tried a few things and no dice
                there is a bug in the electron browser that causes the black screen.
                i did
                npm remove electron
                npm install electron@1.7.9
                and it works fine now…
                someone posted another solution to issue 1243
                A 1 Reply Last reply Reply Quote 1
                  abetterway @sdetweil
                  @sdetweil said in Raspberry 2 clean install showing as black screen:
                  npm remove electron
                  I will have to try that. Thank you! My fix had been to install another web browser and use that. Electron’s built-in browser seemed to always show a black screen.
