    Error Installing Dependencies Permission Denied
    8 Posts 4 Posters 3.8k Views 3 Watching
      BuckGup
      I am getting an error after I run the script to install magic mirror. It gets hung up on installing dependencies with npm. It says permission denied. I have already tried adding sudo in front of the command but that didn’t help. Here’s a picture
      https://imgur.com/ezQwMVR
      • justjim1220J Offline
        justjim1220 Module Developer @BuckGup
        @BuckGup
        Things to try…
        reboot the computer.
        make sure you are signed into github, & into the computer.
        make sure you are connected to the internet.
        delete and reinstall MagicMirror
        use git bash, and install npm install
        might help to copy and paste your error log on here also…
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
          BuckGup @justjim1220
          @justjim1220
          I have rebooted, swapped to ethernet, and reinstalled. But I haven’t signed into github. Do you really need to sign in to clone something? If so how do you sign in through the CLI?
            @buckgup
            I really don’t know, was just a suggestion…
            not quite understanding why its telling you permission denied…
            what command did you use?
            git clone https://github.com/MichMich/MagicMirror.git
            then… npm install ?
            Jim Hallock - 1995
              @justjim1220 Yes this is what I have done. Do I need to be root to install? I am using sudo so it should anyways
                you can’t install in Desktop… its protected…
                use your home folder… then make a shortcut to start the mirror
                  BuckGup @sdetweil
                  @sdetweil Alright thank you. Will try this. By default does it install to desktop or is it because I ran it when I was on the desktop?
                    bhepler Module Developer @BuckGup
                    @buckgup It installed into desktop because that’s the folder you were in when you ran the git command. So:
                    cd /home/pug
                    cd MagicMirror
                    npm install
