    MMM-Assistant google-auth.js
    6 Posts 4 Posters 4.1k Views 4 Watching
    • A
      albertlwj
      can someone help me with this?
      pi@raspberrypi:~/MagicMirror/modules/MMM-Assistant $ node google-auth.js
      internal/modules/cjs/loader.js:550
          throw err;
      Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Assistant/google-auth.js'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:548:15)
          at Function.Module._load (internal/modules/cjs/loader.js:475:25)
          at Function.Module.runMain (internal/modules/cjs/loader.js:695:10)
          at startup (internal/bootstrap/node.js:201:19)
          at bootstrapNodeJSCore (internal/bootstrap/node.js:516:3)
      i can’t get past this step
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @albertlwj
        @albertlwj the file is in a different directory
        do cd scripts first
        • A
          albertlwj
          hello thanks for the heads up…i did but now it gives me another error
          node google-auth.js
          /home/pi/MagicMirror/modules/MMM-Assistant/scripts/google-auth.js:27
          const assistant = new GoogleAssistant(config)
          SyntaxError: Unexpected token const
              at new Script (vm.js:51:7)
              at createScript (vm.js:136:10)
              at Object.runInThisContext (vm.js:197:10)
              at Module._compile (internal/modules/cjs/loader.js:618:28)
              at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
              at Module.load (internal/modules/cjs/loader.js:566:32)
              at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
              at Function.Module._load (internal/modules/cjs/loader.js:498:3)
          • E
            E3V3A
            I don’t think you have installed the module according to the README.
            It seem that you never did npm install.
            But there are some other trouble with that script, that I am trying to fix as we speak…
            “Everything I do (here) is for free – altruism is the way!”
            • E
              E3V3A
              script is fixed! Get the latest script and See comment in the issue you started.
              U 1 Reply Last reply Reply Quote 0
              • U
                umeeq @E3V3A
                @e3v3a I’m having a similar issue after running
                node google-auth.js
                I get the following… what am I missing? It looks like it can’t locate google -client-secret.json but I don’t see a step anywhere where that should have been created.
                node google-auth.js
                    throw err;
                Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Assistant/assets/google-client-secret.json'
                    at Module.require (internal/modules/cjs/loader.js:598:17)
                    at require (internal/modules/cjs/helpers.js:11:18)
                    at new Auth (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/components/auth.js:26:15)
                    at new GoogleAssistant (/home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/index.js:21:16)
                    at Object. (/home/pi/MagicMirror/modules/MMM-Assistant/scripts/google-auth.js:25:19)
                    at Module._compile (internal/modules/cjs/loader.js:654:30)
