    Help with currentweather, remove these number
    4 Posts 3 Posters 2.1k Views 3 Watching
    • T Offline
      tadeus1975
      Hello, I need help to remove this number, which is not the current time and I do not know what it means.
      Thank you
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @tadeus1975
        @tadeus1975 it’s sunrise and sunset. There is no config option for only hiding this, you would need to use a css rule in custom.css to hide it. There is only a config option called onlyTemp, but this is also hiding the wind speed, wind direction, humidity and sunrise/set times.
        • T Offline
          tadeus1975
          Thank you
          • WayneRigleyW Offline
            WayneRigley
            Hello, that number is Sunrise and Sunset. OK first off i also had an issue with that not being correct. regardless what i did. my fault was i DIDNT configure the Raspberry Pi main clock correct. timezone etc under preferences. start there first then this should come into play.
            Wayne R
