    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 241.3k Views 38 Watching
      mongo116 Module Developer @pyrosmiley
      @pyrosmiley Thanks for that. What about the wind, and sunrise / sunset settings? Or were these never merged? Thanks…
      pyrosmileyP 1 Reply Last reply Reply Quote 0
      • pyrosmileyP Offline
        pyrosmiley @mongo116
        @mongo116 sadly I don’t see that those were ever added in and it wasn’t me that did it. I have no idea what I’m doing but sometime soon I’ll see if I can figure it out? I also tried for that awhile back using CSS but didn’t get very far. If you get it let me know, and I’ll do the same!
        • morozgrafixM Offline
          morozgrafix Moderator
          I’ve added some of those on my local branch a long time ago. Feel free to pick from there https://github.com/morozgrafix/MMM-forecast-io/commit/972201f64d432c3c0863a7d76364e7f8af1bb817 and https://github.com/morozgrafix/MMM-forecast-io/commit/13ff8b78c86dc0905e46c11702d7173571517e79
          My fork is fairly old and hasn’t been synced in a while, though.
          It looks like this:
            pyrosmiley
            Very nice! I’ll definitely pull from that then
              rak
              Hi guys,
              I like the concept of the bars for the min/max temperature very much. I wanted the look of the hourly temperature graph a bit more more modern and slick.
              I sat down today and did some code magic. I am surprised how it went. The magicmirror is the first javescript project. So bear with me.
              This is how it looks now.
              I created a fork which I will clean up a bit in the next weeks. Today I am glad it works at all ,-)?
              Enjoy.
              Ralf
              G twosquirrelsT 2 Replies Last reply Reply Quote 3
              • G Offline
                grantc66 @rak
                @rak There seems to be a small error in the script creating the graph:
                // Init chart.js
                this.chart = new Chart(ctx, {
                  type: 'line',
                  data: data,
                  options: options
                Throws an uncaught reference error. Unfortunately I know absolutely nothing about js, can you let me know how to fix it.
                Ta
                  rak
                  You had the plugin before?
                  Have you done this after switching to my fork? It should install chart.js as a dependency.
                  npm install
                  I hope this solves your problem. Let me know.
                  • idoodlerI Offline
                    idoodler Module Developer @paulocarrasco
                    @paulocarrasco Thats an easy one:) You are missing an , after 'my api key'.
                    Here is the correct config:
                          module: 'MMM-forecast-io',
                          position: 'top_right',  // This can be any of the regions.
                            apiKey: 'my api key', // Dark Sky API key.
                            // Only required if geolocation doesn't work:
                            latitude:   37.1468,
                            longitude: -8.5846
                    • G Offline
                      grantc66 @rak
                      @rak Had the original working OK, tried to npm install chart.js in the MM root :(
                      the npm install in the MMM-foecast.io directory fixed it. :)
                      looks great, good work.
                      thanks
                        barnosch
                        @rak
                        Nice work. i just installed it and adjusted for fitting my mirror.
                        Is it possible to shrink the height from the graph?
                        or is it calculated from the width (400px) to keep its aspect ratio?
                          rak
                          Should be easy do adapt. I can check if the height is currently fixed or exposed in the config.js.
                            barnosch
                            guess i found it in the
                            renderPrecipitationGraph: function ()
                            and
                            renderSVGPrecipitationGraph: function ()
                            both heights are calculated there.
                            var width = this.config.precipitationGraphWidth;
                            var height = Math.round(width * 0.3); // 120 by default
                            Played around with the setting, but it did not change anything. Don’t get it currently… mabye you have an idea?
                              barnosch
                              seems not the correct place.
                              Even if comment out both lines with “height” it makes no difference…
                                dudej11
                                Hey! Although this thread is a bit old, I’m wondering if I can get some assistance. I have my DarkSky API key correct, however the console of my Mirror is telling me that it refreshed the access token because it had expired. I checked the API panel, and it did indeed show that the API had been called, so my API key is correct. However, the weather module never loaded. Any suggestions?
                                  barnosch
                                  Other moduls are showing?
                                  Have you tried with the above example from idoodler?
                                  Otherwise try to delete the folder again, pull it again and don’t forget to “npm install” in the just downloaded folder.
                                  • twosquirrelsT Offline
                                    twosquirrels @rak
                                    @rak
                                    Thanks for this fork! I like your sample screenshot. I cloned it and did npm install, but the sizing of all the colored elements are all way off. Any ideas?
                                    Why is it showing 10 degrees all the way up through 70 when it really only needs to show 70 to 95?
                                    The rain bars are too tiny, as are the temperature range bars. :disappointed_face:
                                      rak
                                      because it meant to be for Grad Celcius and not Grad Fahrenheit. When ever will US go to a metric system ,-).
                                      Fix is easy.
                                      Search in modules/MMM-forecast-io/MMM-forecast-io.js for
                                                  position: 'left',
                                                  ticks: {
                                                    suggestedMin: 10,
                                      and change suggestedMin to you choosing, like 70 … .
                                      Enjoy.
                                      For the bars. You need more space. Make the module wider, or reduce the font size (custom.css).
                                        justindp2006
                                        Been trying to use this module but the width is taking up almost the whole screen. I’m assuming size needs adjusted in the css file but I don’t know which is causing this. Ideas?
                                          barnosch
                                          you can maybe try the following.
                                          Add to your custom.css
                                          .MMM-forecast-io{
                                          transform: scale(0.90, 0.90);
                                          Code was not tested. the 0.90 stands for 90%
                                          Maybe that works and is good enough for your needs
                                          otherwise look for the css file within the module folder and play with the settings there
                                            justindp2006
                                            Thank you! So interesting tid-bit. It works on Browser View mode (IP:8080) but on the mirror itself, no changes. I also have trouble with another module. It shows on the Browser, but not at the mirror. It must be something with the Pi Zero image I’m using.
                                            • 5 / 7
