    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 244.9k Views 38 Watching
    • pyrosmileyP
      pyrosmiley @dmcinnes
      @dmcinnes Oh, okay — that makes a lot of sense! Glad to know it’s not just me missing something. I’ll take a look at the html and see what I can do, thanks for pointing that out for me.
        mongo116 Module Developer @jinjirosan
        @jinjirosan Hi, have you made the changes available to download? Would like to give it a go as currently using a combination of the default weather and forecast-io.
        pyrosmileyP 1 Reply Last reply
          Basanth_Kumar
          Hello! as i am completely new to this MM…i am unable to where the icons images are placed…if anybody knows that,guide me , so that i want to change the UI for mine…
          • pyrosmileyP
            pyrosmiley @mongo116
            @mongo116 The changes were merged into the main branch of the module, so if you’re up to date, then you should be able to add ‘’’precipitationFillColor’’’ to your config. I added a description and some other info to the readme as well.
            M 1 Reply Last reply
            • pyrosmileyP
              pyrosmiley @Basanth_Kumar
              @Basanth_Kumar I’m on my phone so I can’t look up links very effectively, but there are a couple of guides on the forums that are good for learning how to setup your configuration file. The official guide on the github page is also pretty thorough. It definitely took some trial and error for me to get up and running (gotta pay attention to those commas!) but you’ll get it. Just follow those guides, and just change one little thing at a time so you can learn to see how it works — you’ll get the hang of it!
                mongo116 Module Developer @pyrosmiley
                @pyrosmiley Thanks for that. What about the wind, and sunrise / sunset settings? Or were these never merged? Thanks…
                • pyrosmileyP
                  @mongo116 sadly I don’t see that those were ever added in and it wasn’t me that did it. I have no idea what I’m doing but sometime soon I’ll see if I can figure it out? I also tried for that awhile back using CSS but didn’t get very far. If you get it let me know, and I’ll do the same!
                  • morozgrafixM
                    morozgrafix Moderator
                    I’ve added some of those on my local branch a long time ago. Feel free to pick from there https://github.com/morozgrafix/MMM-forecast-io/commit/972201f64d432c3c0863a7d76364e7f8af1bb817 and https://github.com/morozgrafix/MMM-forecast-io/commit/13ff8b78c86dc0905e46c11702d7173571517e79
                    My fork is fairly old and hasn’t been synced in a while, though.
                    It looks like this:
                    • pyrosmileyP
                      pyrosmiley
                      Very nice! I’ll definitely pull from that then
                        rak
                        Hi guys,
                        I like the concept of the bars for the min/max temperature very much. I wanted the look of the hourly temperature graph a bit more more modern and slick.
                        I sat down today and did some code magic. I am surprised how it went. The magicmirror is the first javescript project. So bear with me.
                        This is how it looks now.
                        I created a fork which I will clean up a bit in the next weeks. Today I am glad it works at all ,-)?
                        Enjoy.
                        Ralf
                        G twosquirrelsT 2 Replies Last reply
                        Reply Quote 3
                        • G
                          grantc66 @rak
                          @rak There seems to be a small error in the script creating the graph:
                          // Init chart.js
                          this.chart = new Chart(ctx, {
                            type: 'line',
                            data: data,
                            options: options
                          Throws an uncaught reference error. Unfortunately I know absolutely nothing about js, can you let me know how to fix it.
                          Ta
                            rak
                            You had the plugin before?
                            Have you done this after switching to my fork? It should install chart.js as a dependency.
                            npm install
                            I hope this solves your problem. Let me know.
                            G 1 Reply Last reply
                            • idoodlerI
                              idoodler Module Developer @paulocarrasco
                              @paulocarrasco Thats an easy one:) You are missing an , after 'my api key'.
                              Here is the correct config:
                                    module: 'MMM-forecast-io',
                                    position: 'top_right',  // This can be any of the regions.
                                      apiKey: 'my api key', // Dark Sky API key.
                                      // Only required if geolocation doesn't work:
                                      latitude:   37.1468,
                                      longitude: -8.5846
                              • G
                                grantc66 @rak
                                @rak Had the original working OK, tried to npm install chart.js in the MM root :(
                                the npm install in the MMM-foecast.io directory fixed it. :)
                                looks great, good work.
                                thanks
                                  barnosch
                                  @rak
                                  Nice work. i just installed it and adjusted for fitting my mirror.
                                  Is it possible to shrink the height from the graph?
                                  or is it calculated from the width (400px) to keep its aspect ratio?
                                    rak
                                    Should be easy do adapt. I can check if the height is currently fixed or exposed in the config.js.
                                      barnosch
                                      guess i found it in the
                                      renderPrecipitationGraph: function ()
                                      and
                                      renderSVGPrecipitationGraph: function ()
                                      both heights are calculated there.
                                      var width = this.config.precipitationGraphWidth;
                                      var height = Math.round(width * 0.3); // 120 by default
                                      Played around with the setting, but it did not change anything. Don’t get it currently… mabye you have an idea?
                                        barnosch
                                        seems not the correct place.
                                        Even if comment out both lines with “height” it makes no difference…
                                          dudej11
                                          Hey! Although this thread is a bit old, I’m wondering if I can get some assistance. I have my DarkSky API key correct, however the console of my Mirror is telling me that it refreshed the access token because it had expired. I checked the API panel, and it did indeed show that the API had been called, so my API key is correct. However, the weather module never loaded. Any suggestions?
                                            barnosch
                                            Other moduls are showing?
                                            Have you tried with the above example from idoodler?
                                            Otherwise try to delete the folder again, pull it again and don’t forget to “npm install” in the just downloaded folder.
                                            • 5 / 7
