    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 246.8k Views 38 Watching
    • pyrosmileyP
      pyrosmiley
      Very nice! I’ll definitely pull from that then
        rak
        Hi guys,
        I like the concept of the bars for the min/max temperature very much. I wanted the look of the hourly temperature graph a bit more more modern and slick.
        I sat down today and did some code magic. I am surprised how it went. The magicmirror is the first javescript project. So bear with me.
        This is how it looks now.
        I created a fork which I will clean up a bit in the next weeks. Today I am glad it works at all ,-)?
        Enjoy.
        Ralf
        G twosquirrelsT 2 Replies Last reply
        Reply Quote 3
        • G
          grantc66 @rak
          @rak There seems to be a small error in the script creating the graph:
          // Init chart.js
          this.chart = new Chart(ctx, {
            type: 'line',
            data: data,
            options: options
          Throws an uncaught reference error. Unfortunately I know absolutely nothing about js, can you let me know how to fix it.
          Ta
            rak
            You had the plugin before?
            Have you done this after switching to my fork? It should install chart.js as a dependency.
            npm install
            I hope this solves your problem. Let me know.
            G 1 Reply Last reply
            • idoodlerI
              idoodler Module Developer @paulocarrasco
              @paulocarrasco Thats an easy one:) You are missing an , after 'my api key'.
              Here is the correct config:
                    module: 'MMM-forecast-io',
                    position: 'top_right',  // This can be any of the regions.
                      apiKey: 'my api key', // Dark Sky API key.
                      // Only required if geolocation doesn't work:
                      latitude:   37.1468,
                      longitude: -8.5846
              • G
                grantc66 @rak
                @rak Had the original working OK, tried to npm install chart.js in the MM root :(
                the npm install in the MMM-foecast.io directory fixed it. :)
                looks great, good work.
                thanks
                  barnosch
                  @rak
                  Nice work. i just installed it and adjusted for fitting my mirror.
                  Is it possible to shrink the height from the graph?
                  or is it calculated from the width (400px) to keep its aspect ratio?
                    rak
                    Should be easy do adapt. I can check if the height is currently fixed or exposed in the config.js.
                      barnosch
                      guess i found it in the
                      renderPrecipitationGraph: function ()
                      and
                      renderSVGPrecipitationGraph: function ()
                      both heights are calculated there.
                      var width = this.config.precipitationGraphWidth;
                      var height = Math.round(width * 0.3); // 120 by default
                      Played around with the setting, but it did not change anything. Don’t get it currently… mabye you have an idea?
                        barnosch
                        seems not the correct place.
                        Even if comment out both lines with “height” it makes no difference…
                          dudej11
                          Hey! Although this thread is a bit old, I’m wondering if I can get some assistance. I have my DarkSky API key correct, however the console of my Mirror is telling me that it refreshed the access token because it had expired. I checked the API panel, and it did indeed show that the API had been called, so my API key is correct. However, the weather module never loaded. Any suggestions?
                            barnosch
                            Other moduls are showing?
                            Have you tried with the above example from idoodler?
                            Otherwise try to delete the folder again, pull it again and don’t forget to “npm install” in the just downloaded folder.
                            • twosquirrelsT
                              twosquirrels @rak
                              @rak
                              Thanks for this fork! I like your sample screenshot. I cloned it and did npm install, but the sizing of all the colored elements are all way off. Any ideas?
                              Why is it showing 10 degrees all the way up through 70 when it really only needs to show 70 to 95?
                              The rain bars are too tiny, as are the temperature range bars. :disappointed_face:
                                rak
                                because it meant to be for Grad Celcius and not Grad Fahrenheit. When ever will US go to a metric system ,-).
                                Fix is easy.
                                Search in modules/MMM-forecast-io/MMM-forecast-io.js for
                                            position: 'left',
                                            ticks: {
                                              suggestedMin: 10,
                                and change suggestedMin to you choosing, like 70 … .
                                Enjoy.
                                For the bars. You need more space. Make the module wider, or reduce the font size (custom.css).
                                  justindp2006
                                  Been trying to use this module but the width is taking up almost the whole screen. I’m assuming size needs adjusted in the css file but I don’t know which is causing this. Ideas?
                                    barnosch
                                    you can maybe try the following.
                                    Add to your custom.css
                                    .MMM-forecast-io{
                                    transform: scale(0.90, 0.90);
                                    Code was not tested. the 0.90 stands for 90%
                                    Maybe that works and is good enough for your needs
                                    otherwise look for the css file within the module folder and play with the settings there
                                      justindp2006
                                      Thank you! So interesting tid-bit. It works on Browser View mode (IP:8080) but on the mirror itself, no changes. I also have trouble with another module. It shows on the Browser, but not at the mirror. It must be something with the Pi Zero image I’m using.
                                      • lavolp3L
                                        lavolp3 Module Developer
                                        Guys, going through the thread, I see that a lot of good ideas were implemented in forks but not sent as PRs. I think it would be a good idea to have some of these included into the original. dmcinnes/MMM-forecast-io, since this is the one referenced in the original MagicMirror.
                                        @dmcinnes what do you think?
                                        Do you want this rep to be bloated up or do you want it to be kept mostly as it is and leave major changes to forks?
                                        I would expect at least to have some of @morozgrafix very good ideas implemented as optional (sunset, precipitation probability).
                                        Also @rak 's ideas look very very promising but I admit might be a bit much as changes for the master.
                                        How to troubleshoot modules
                                        MMM-soccer v2, MMM-AVStock
                                        morozgrafixM 2 Replies Last reply
                                        • morozgrafixM
                                          morozgrafix Moderator @lavolp3
                                          @lavolp3 I haven’t pulled from master repo in a while and not sure if my changes are compatible at this point. I’m happy to clean it up, test it and submit a PR. Just let me know.
                                          lavolp3L 1 Reply Last reply
                                          • lavolp3L
                                            lavolp3 Module Developer @morozgrafix
                                            @morozgrafix Guess I’ll use the weekend to steal from all of you and build my perfect module. And learn stuff!
                                            Might also send a few PRs then because I’m new to git and it really satisfies me :-D
                                            morozgrafixM 1 Reply Last reply
                                            • 5 / 7
