    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 246.8k Views 38 Watching
      rak
      You had the plugin before?
      Have you done this after switching to my fork? It should install chart.js as a dependency.
      npm install
      I hope this solves your problem. Let me know.
      G 1 Reply Last reply
      • idoodlerI
        idoodler Module Developer @paulocarrasco
        @paulocarrasco Thats an easy one:) You are missing an , after 'my api key'.
        Here is the correct config:
              module: 'MMM-forecast-io',
              position: 'top_right',  // This can be any of the regions.
                apiKey: 'my api key', // Dark Sky API key.
                // Only required if geolocation doesn't work:
                latitude:   37.1468,
                longitude: -8.5846
        • G
          grantc66 @rak
          @rak Had the original working OK, tried to npm install chart.js in the MM root :(
          the npm install in the MMM-foecast.io directory fixed it. :)
          looks great, good work.
          thanks
            barnosch
            @rak
            Nice work. i just installed it and adjusted for fitting my mirror.
            Is it possible to shrink the height from the graph?
            or is it calculated from the width (400px) to keep its aspect ratio?
              rak
              Should be easy do adapt. I can check if the height is currently fixed or exposed in the config.js.
                barnosch
                guess i found it in the
                renderPrecipitationGraph: function ()
                and
                renderSVGPrecipitationGraph: function ()
                both heights are calculated there.
                var width = this.config.precipitationGraphWidth;
                var height = Math.round(width * 0.3); // 120 by default
                Played around with the setting, but it did not change anything. Don’t get it currently… mabye you have an idea?
                  barnosch
                  seems not the correct place.
                  Even if comment out both lines with “height” it makes no difference…
                    dudej11
                    Hey! Although this thread is a bit old, I’m wondering if I can get some assistance. I have my DarkSky API key correct, however the console of my Mirror is telling me that it refreshed the access token because it had expired. I checked the API panel, and it did indeed show that the API had been called, so my API key is correct. However, the weather module never loaded. Any suggestions?
                      barnosch
                      Other moduls are showing?
                      Have you tried with the above example from idoodler?
                      Otherwise try to delete the folder again, pull it again and don’t forget to “npm install” in the just downloaded folder.
                      • twosquirrelsT
                        twosquirrels @rak
                        @rak
                        Thanks for this fork! I like your sample screenshot. I cloned it and did npm install, but the sizing of all the colored elements are all way off. Any ideas?
                        Why is it showing 10 degrees all the way up through 70 when it really only needs to show 70 to 95?
                        The rain bars are too tiny, as are the temperature range bars. :disappointed_face:
                          rak
                          because it meant to be for Grad Celcius and not Grad Fahrenheit. When ever will US go to a metric system ,-).
                          Fix is easy.
                          Search in modules/MMM-forecast-io/MMM-forecast-io.js for
                                      position: 'left',
                                      ticks: {
                                        suggestedMin: 10,
                          and change suggestedMin to you choosing, like 70 … .
                          Enjoy.
                          For the bars. You need more space. Make the module wider, or reduce the font size (custom.css).
                            justindp2006
                            Been trying to use this module but the width is taking up almost the whole screen. I’m assuming size needs adjusted in the css file but I don’t know which is causing this. Ideas?
                              barnosch
                              you can maybe try the following.
                              Add to your custom.css
                              .MMM-forecast-io{
                              transform: scale(0.90, 0.90);
                              Code was not tested. the 0.90 stands for 90%
                              Maybe that works and is good enough for your needs
                              otherwise look for the css file within the module folder and play with the settings there
                                justindp2006
                                Thank you! So interesting tid-bit. It works on Browser View mode (IP:8080) but on the mirror itself, no changes. I also have trouble with another module. It shows on the Browser, but not at the mirror. It must be something with the Pi Zero image I’m using.
                                • lavolp3L
                                  lavolp3 Module Developer
                                  Guys, going through the thread, I see that a lot of good ideas were implemented in forks but not sent as PRs. I think it would be a good idea to have some of these included into the original. dmcinnes/MMM-forecast-io, since this is the one referenced in the original MagicMirror.
                                  @dmcinnes what do you think?
                                  Do you want this rep to be bloated up or do you want it to be kept mostly as it is and leave major changes to forks?
                                  I would expect at least to have some of @morozgrafix very good ideas implemented as optional (sunset, precipitation probability).
                                  Also @rak 's ideas look very very promising but I admit might be a bit much as changes for the master.
                                  How to troubleshoot modules
                                  MMM-soccer v2, MMM-AVStock
                                  morozgrafixM 2 Replies Last reply
                                  • morozgrafixM
                                    morozgrafix Moderator @lavolp3
                                    @lavolp3 I haven’t pulled from master repo in a while and not sure if my changes are compatible at this point. I’m happy to clean it up, test it and submit a PR. Just let me know.
                                    lavolp3L 1 Reply Last reply
                                    • lavolp3L
                                      lavolp3 Module Developer @morozgrafix
                                      @morozgrafix Guess I’ll use the weekend to steal from all of you and build my perfect module. And learn stuff!
                                      Might also send a few PRs then because I’m new to git and it really satisfies me :-D
                                      morozgrafixM 1 Reply Last reply
                                      • morozgrafixM
                                        @lavolp3 One thing that I would suggest is to group your changes into relevant and smaller size chunks and submit separate PRs for those, instead of one massive PR. It’s easier for reviewers and for you in case you need to make changes based on comments. Cheers.
                                        • morozgrafixM
                                          @lavolp3 said in MMM-forecast-io -- Localized up to the minute weather:
                                          I just submitted a PR for displaying Sunrise and Sunset times. https://github.com/dmcinnes/MMM-forecast-io/pull/22
                                          I will try to find some time to improve wind forecast and get another PR submitted sometime this weekend.
                                          I also just submitted a PR for wind speed and direction https://github.com/dmcinnes/MMM-forecast-io/pull/23
                                          Precipitation probability forecast is also submitted as a PR: https://github.com/dmcinnes/MMM-forecast-io/pull/24
                                          I also sneaked another PR that allows easy adjustments to forecast table look and feel: https://github.com/dmcinnes/MMM-forecast-io/pull/25
                                            12wsx
                                            what is the problem with my module? the problem is on monitor connected to raspberry pi Zero (using midori browser) where MagicMirror is installed.
                                            My config:
                                            /* Magic Mirror Config Sample
                                             * MIT Licensed.
                                            var config = {
                                            	address: "::", // Address to listen on, can be:
                                            	port: 8080,
                                            	ipWhitelist: [], // Set [] to allow all IP addresses
                                            	language: "pl",
                                            	timeFormat: 24,
                                            	units: "metric",
                                            			module: "alert",
                                            			module: "clock",
                                            			position: "top_left"
                                            						symbol: "calendar-check-o ",
                                            						url: "https://calendar.google.com/xxxxxxxx"
                                            			module: "MMM-Solartemp",
                                            			position: "bottom_left",
                                            			header: "Solartemp",
                                            				baseURL: "http://xxxxxxxxxx",
                                            				key: "xxxxxxxxx",
                                            				group: "xxxxxx",
                                                			module: 'MMM-Remote-Control'
                                                			// , position: 'bottom_left'
                                                  				apiKey: 'xxxxxxx', // Dark Sky API key.
                                                  				maxDaysForecast: 5,
                                            				forecastTableFontSize: 'small',
                                                  				latitude:  xx.xxxx,
                                                  				longitude: xx.xxxx
                                            alt text
                                            idoodlerI 1 Reply Last reply
                                            • 5 / 7
