    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 245.0k Views 38 Watching
      dudej11
      Hey! Although this thread is a bit old, I’m wondering if I can get some assistance. I have my DarkSky API key correct, however the console of my Mirror is telling me that it refreshed the access token because it had expired. I checked the API panel, and it did indeed show that the API had been called, so my API key is correct. However, the weather module never loaded. Any suggestions?
        barnosch
        Other moduls are showing?
        Have you tried with the above example from idoodler?
        Otherwise try to delete the folder again, pull it again and don’t forget to “npm install” in the just downloaded folder.
        • twosquirrelsT
          twosquirrels @rak
          @rak
          Thanks for this fork! I like your sample screenshot. I cloned it and did npm install, but the sizing of all the colored elements are all way off. Any ideas?
          Why is it showing 10 degrees all the way up through 70 when it really only needs to show 70 to 95?
          The rain bars are too tiny, as are the temperature range bars. :disappointed_face:
            rak
            because it meant to be for Grad Celcius and not Grad Fahrenheit. When ever will US go to a metric system ,-).
            Fix is easy.
            Search in modules/MMM-forecast-io/MMM-forecast-io.js for
                        position: 'left',
                        ticks: {
                          suggestedMin: 10,
            and change suggestedMin to you choosing, like 70 … .
            Enjoy.
            For the bars. You need more space. Make the module wider, or reduce the font size (custom.css).
              justindp2006
              Been trying to use this module but the width is taking up almost the whole screen. I’m assuming size needs adjusted in the css file but I don’t know which is causing this. Ideas?
                barnosch
                you can maybe try the following.
                Add to your custom.css
                .MMM-forecast-io{
                transform: scale(0.90, 0.90);
                Code was not tested. the 0.90 stands for 90%
                Maybe that works and is good enough for your needs
                otherwise look for the css file within the module folder and play with the settings there
                  justindp2006
                  Thank you! So interesting tid-bit. It works on Browser View mode (IP:8080) but on the mirror itself, no changes. I also have trouble with another module. It shows on the Browser, but not at the mirror. It must be something with the Pi Zero image I’m using.
                  • lavolp3L
                    lavolp3 Module Developer
                    Guys, going through the thread, I see that a lot of good ideas were implemented in forks but not sent as PRs. I think it would be a good idea to have some of these included into the original. dmcinnes/MMM-forecast-io, since this is the one referenced in the original MagicMirror.
                    @dmcinnes what do you think?
                    Do you want this rep to be bloated up or do you want it to be kept mostly as it is and leave major changes to forks?
                    I would expect at least to have some of @morozgrafix very good ideas implemented as optional (sunset, precipitation probability).
                    Also @rak 's ideas look very very promising but I admit might be a bit much as changes for the master.
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                    morozgrafixM 2 Replies Last reply
                    • morozgrafixM
                      morozgrafix Moderator @lavolp3
                      @lavolp3 I haven’t pulled from master repo in a while and not sure if my changes are compatible at this point. I’m happy to clean it up, test it and submit a PR. Just let me know.
                      lavolp3L 1 Reply Last reply
                      • lavolp3L
                        lavolp3 Module Developer @morozgrafix
                        @morozgrafix Guess I’ll use the weekend to steal from all of you and build my perfect module. And learn stuff!
                        Might also send a few PRs then because I’m new to git and it really satisfies me :-D
                        morozgrafixM 1 Reply Last reply
                        • morozgrafixM
                          @lavolp3 One thing that I would suggest is to group your changes into relevant and smaller size chunks and submit separate PRs for those, instead of one massive PR. It’s easier for reviewers and for you in case you need to make changes based on comments. Cheers.
                          • morozgrafixM
                            @lavolp3 said in MMM-forecast-io -- Localized up to the minute weather:
                            I just submitted a PR for displaying Sunrise and Sunset times. https://github.com/dmcinnes/MMM-forecast-io/pull/22
                            I will try to find some time to improve wind forecast and get another PR submitted sometime this weekend.
                            I also just submitted a PR for wind speed and direction https://github.com/dmcinnes/MMM-forecast-io/pull/23
                            Precipitation probability forecast is also submitted as a PR: https://github.com/dmcinnes/MMM-forecast-io/pull/24
                            I also sneaked another PR that allows easy adjustments to forecast table look and feel: https://github.com/dmcinnes/MMM-forecast-io/pull/25
                              12wsx
                              what is the problem with my module? the problem is on monitor connected to raspberry pi Zero (using midori browser) where MagicMirror is installed.
                              My config:
                              /* Magic Mirror Config Sample
                               * MIT Licensed.
                              var config = {
                              	address: "::", // Address to listen on, can be:
                              	port: 8080,
                              	ipWhitelist: [], // Set [] to allow all IP addresses
                              	language: "pl",
                              	timeFormat: 24,
                              	units: "metric",
                              			module: "alert",
                              			module: "clock",
                              			position: "top_left"
                              						symbol: "calendar-check-o ",
                              						url: "https://calendar.google.com/xxxxxxxx"
                              			module: "MMM-Solartemp",
                              			position: "bottom_left",
                              			header: "Solartemp",
                              				baseURL: "http://xxxxxxxxxx",
                              				key: "xxxxxxxxx",
                              				group: "xxxxxx",
                                  			module: 'MMM-Remote-Control'
                                  			// , position: 'bottom_left'
                              				module: 'MMM-forecast-io',
                                  				position: 'top_right',  // This can be any of the regions.
                                    				apiKey: 'xxxxxxx', // Dark Sky API key.
                                    				maxDaysForecast: 5,
                              				forecastTableFontSize: 'small',
                              				// Only required if geolocation doesn't work:
                                    				latitude:  xx.xxxx,
                                    				longitude: xx.xxxx
                              alt text
                              idoodlerI 1 Reply Last reply
                              • idoodlerI
                                idoodler Module Developer @12wsx
                                @12wsx Are you using some custom CSS?
                                  12wsx
                                  no i don’t use custom css. But one thing- when I connect to magic mirror from my
                                  computer (win7 /firefox) everything is ok.
                                  • idoodlerI
                                    @12wsx Did you try using Chromium as a browser? Midori may have a hard time rendering the page.
                                    • H
                                      henryluyu
                                      Hi this is this module in my config.js.
                                      I simply put the “MMM-forecast-io-master” folder in /modules/default, I have also put my actual api key, latitude and longtitude values also in MMM-forecast-io.js. But no weather is showing, other modules working fine. Can anyone help please?
        apiKey: 'MYAPIKEY',
        latitude:   53.4839,
        longitude:  -2.2446
                                      Mykle1M 1 Reply Last reply
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @henryluyu
                                        @henryluyu said in MMM-forecast-io -- Localized up to the minute weather:
                                        1. Folder name should just be MMM-forecast-io
                                        2. Goes in modules folder, not the default folder
                                        That is not recommended. Putting those in your config.js will suffice.
                                        • F
                                          Fifin404
                                          Hi, is possible add “C” in all temperatures? Like 21 °C
                                          and for wind add “km/h” like 8 km/h
                                          C 1 Reply Last reply
                                            code999
                                            Hey all, anyone know how to get rid of the round bar in between the temps? 0_1574871951039_511494cd-8516-4507-93f2-b773a560930b-image.png
                                            Thanks in advance.
                                            • 6 / 7
