    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 244.7k Views 38 Watching
      justindp2006
      Thank you! So interesting tid-bit. It works on Browser View mode (IP:8080) but on the mirror itself, no changes. I also have trouble with another module. It shows on the Browser, but not at the mirror. It must be something with the Pi Zero image I’m using.
      • lavolp3L
        lavolp3 Module Developer
        Guys, going through the thread, I see that a lot of good ideas were implemented in forks but not sent as PRs. I think it would be a good idea to have some of these included into the original. dmcinnes/MMM-forecast-io, since this is the one referenced in the original MagicMirror.
        @dmcinnes what do you think?
        Do you want this rep to be bloated up or do you want it to be kept mostly as it is and leave major changes to forks?
        I would expect at least to have some of @morozgrafix very good ideas implemented as optional (sunset, precipitation probability).
        Also @rak 's ideas look very very promising but I admit might be a bit much as changes for the master.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        morozgrafixM 2 Replies Last reply Reply Quote 0
        • morozgrafixM
          morozgrafix Moderator @lavolp3
          @lavolp3 I haven’t pulled from master repo in a while and not sure if my changes are compatible at this point. I’m happy to clean it up, test it and submit a PR. Just let me know.
          • lavolp3L
            lavolp3 Module Developer @morozgrafix
            @morozgrafix Guess I’ll use the weekend to steal from all of you and build my perfect module. And learn stuff!
            Might also send a few PRs then because I’m new to git and it really satisfies me :-D
            morozgrafixM 1 Reply Last reply Reply Quote 0
            • morozgrafixM
              @lavolp3 One thing that I would suggest is to group your changes into relevant and smaller size chunks and submit separate PRs for those, instead of one massive PR. It’s easier for reviewers and for you in case you need to make changes based on comments. Cheers.
              • morozgrafixM
                @lavolp3 said in MMM-forecast-io -- Localized up to the minute weather:
                I just submitted a PR for displaying Sunrise and Sunset times. https://github.com/dmcinnes/MMM-forecast-io/pull/22
                I will try to find some time to improve wind forecast and get another PR submitted sometime this weekend.
                I also just submitted a PR for wind speed and direction https://github.com/dmcinnes/MMM-forecast-io/pull/23
                Precipitation probability forecast is also submitted as a PR: https://github.com/dmcinnes/MMM-forecast-io/pull/24
                I also sneaked another PR that allows easy adjustments to forecast table look and feel: https://github.com/dmcinnes/MMM-forecast-io/pull/25
                  12wsx
                  what is the problem with my module? the problem is on monitor connected to raspberry pi Zero (using midori browser) where MagicMirror is installed.
                  My config:
                  /* Magic Mirror Config Sample
                   * MIT Licensed.
                  var config = {
                  	address: "::", // Address to listen on, can be:
                  	port: 8080,
                  	ipWhitelist: [], // Set [] to allow all IP addresses
                  	language: "pl",
                  	timeFormat: 24,
                  	units: "metric",
                  			module: "alert",
                  			module: "clock",
                  			position: "top_left"
                  						symbol: "calendar-check-o ",
                  						url: "https://calendar.google.com/xxxxxxxx"
                  			module: "MMM-Solartemp",
                  			position: "bottom_left",
                  			header: "Solartemp",
                  				baseURL: "http://xxxxxxxxxx",
                  				key: "xxxxxxxxx",
                  				group: "xxxxxx",
                      			module: 'MMM-Remote-Control'
                      			// , position: 'bottom_left'
                  				module: 'MMM-forecast-io',
                      				position: 'top_right',  // This can be any of the regions.
                        				apiKey: 'xxxxxxx', // Dark Sky API key.
                        				maxDaysForecast: 5,
                  				forecastTableFontSize: 'small',
                  				// Only required if geolocation doesn't work:
                        				latitude:  xx.xxxx,
                        				longitude: xx.xxxx
                  alt text
                  idoodlerI 1 Reply Last reply Reply Quote 0
                  • idoodlerI
                    idoodler Module Developer @12wsx
                    @12wsx Are you using some custom CSS?
                      12wsx
                      no i don’t use custom css. But one thing- when I connect to magic mirror from my
                      computer (win7 /firefox) everything is ok.
                      • idoodlerI
                        @12wsx Did you try using Chromium as a browser? Midori may have a hard time rendering the page.
                        • H
                          henryluyu
                          Hi this is this module in my config.js.
                          I simply put the “MMM-forecast-io-master” folder in /modules/default, I have also put my actual api key, latitude and longtitude values also in MMM-forecast-io.js. But no weather is showing, other modules working fine. Can anyone help please?
                                                     apiKey: 'MYAPIKEY',
                                                     latitude:   53.4839,
                                                     longitude:  -2.2446
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @henryluyu
                            @henryluyu said in MMM-forecast-io -- Localized up to the minute weather:
                            1. Folder name should just be MMM-forecast-io
                            2. Goes in modules folder, not the default folder
                            That is not recommended. Putting those in your config.js will suffice.
                            • F
                              Fifin404
                              Hi, is possible add “C” in all temperatures? Like 21 °C
                              and for wind add “km/h” like 8 km/h
                                code999
                                Hey all, anyone know how to get rid of the round bar in between the temps? 0_1574871951039_511494cd-8516-4507-93f2-b773a560930b-image.png
                                Thanks in advance.
                                • morozgrafixM
                                  morozgrafix Moderator @code999
                                  @code999 you can comment out this line forecastBar.appendChild(bar); but it will look kind of bad. Those bars are sort of a default look that you get from darksky/forecast UI.
                                    code999 @morozgrafix
                                    @morozgrafix what file do I edit? I can not find that line to comment it out. Thanks.
                                    morozgrafixM lavolp3L 2 Replies Last reply Reply Quote 0
                                    • morozgrafixM
                                      @code999 it’s line 397 in MMM-fotecast-io.js https://github.com/dmcinnes/MMM-forecast-io/blob/77075e1c9011336f044d35f1c964fc93789a4201/MMM-forecast-io.js#L397
                                      • lavolp3L
                                        lavolp3 Module Developer @code999
                                        @code999 it’s in the MMM-forecast-io.js file.
                                        You can either try to comment out (//) or delete line 397
                                        (only the bar)
                                        or line 402
                                        forecastBarWrapper.appendChild(forecastBar);
                                        (with temps)
                                        But why are you trying to delete it? It really doesn’t make sense to me and will look kind of ugly I guess.
                                          code999 @lavolp3
                                          @lavolp3 @morozgrafix Thank you both. I like an even look and the bar IMO is unless. when there is a large difference in temp it looks ridiculous. I might add something between numbers to give it some space and cleaner look. I did it mainly for space. I have it on the right side with my calendar taking up most of the screen. Anyway thanks again.
                                            code999 @Fifin404
                                            @Fifin404 I would like this also. Did you get it to show?
                                            F lavolp3L 2 Replies Last reply Reply Quote 0
                                            • 6 / 7
