    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 245.0k Views 38 Watching
    • idoodlerI
      idoodler Module Developer @12wsx
      @12wsx Did you try using Chromium as a browser? Midori may have a hard time rendering the page.
      • H
        henryluyu
        Hi this is this module in my config.js.
        I simply put the “MMM-forecast-io-master” folder in /modules/default, I have also put my actual api key, latitude and longtitude values also in MMM-forecast-io.js. But no weather is showing, other modules working fine. Can anyone help please?
                            module: 'MMM-forecast-io',
                            position: 'top_right',
                                   apiKey: 'MYAPIKEY',
                                   latitude:   53.4839,
                                   longitude:  -2.2446
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @henryluyu
          @henryluyu said in MMM-forecast-io -- Localized up to the minute weather:
          1. Folder name should just be MMM-forecast-io
          2. Goes in modules folder, not the default folder
          That is not recommended. Putting those in your config.js will suffice.
          • F
            Fifin404
            Hi, is possible add “C” in all temperatures? Like 21 °C
            and for wind add “km/h” like 8 km/h
            C 1 Reply Last reply
              code999
              Hey all, anyone know how to get rid of the round bar in between the temps? 0_1574871951039_511494cd-8516-4507-93f2-b773a560930b-image.png
              Thanks in advance.
              morozgrafixM 1 Reply Last reply
              • morozgrafixM
                morozgrafix Moderator @code999
                @code999 you can comment out this line forecastBar.appendChild(bar); but it will look kind of bad. Those bars are sort of a default look that you get from darksky/forecast UI.
                  code999 @morozgrafix
                  @morozgrafix what file do I edit? I can not find that line to comment it out. Thanks.
                  morozgrafixM lavolp3L 2 Replies Last reply
                  • morozgrafixM
                    @code999 it’s line 397 in MMM-fotecast-io.js https://github.com/dmcinnes/MMM-forecast-io/blob/77075e1c9011336f044d35f1c964fc93789a4201/MMM-forecast-io.js#L397
                    • lavolp3L
                      lavolp3 Module Developer @code999
                      @code999 it’s in the MMM-forecast-io.js file.
                      You can either try to comment out (//) or delete line 397
                      (only the bar)
                      or line 402
                      forecastBarWrapper.appendChild(forecastBar);
                      (with temps)
                      But why are you trying to delete it? It really doesn’t make sense to me and will look kind of ugly I guess.
                      How to troubleshoot modules
                      MMM-soccer v2, MMM-AVStock
                        code999 @lavolp3
                        @lavolp3 @morozgrafix Thank you both. I like an even look and the bar IMO is unless. when there is a large difference in temp it looks ridiculous. I might add something between numbers to give it some space and cleaner look. I did it mainly for space. I have it on the right side with my calendar taking up most of the screen. Anyway thanks again.
                          code999 @Fifin404
                          @Fifin404 I would like this also. Did you get it to show?
                          F lavolp3L 2 Replies Last reply
                          • F
                            Fifin404 @code999
                            @code999 NO, I use another module
                            • lavolp3L
                              @code999 @Fifin404
                              You can add the “C” by putting this into your custom.css
                              .MMM-forecast-io .bright:after {
                                content: "C";
                              That adds a “C” after the content of every element with the class “bright”. Luckily the temperature seems to be the only one.
                              For the km/h, you would need to change the code of the main .js file, because wind is apparently calculated in m/s and you have to add the conversion factor 3.6 to convert to km/h.
                              It’s possible of course but you should then consider forking the whole module and/or create a PR for that.
                                ChickenBeard
                                Is it possible to have the precipitation graph ONLY? I enabled it (and disabled the general “Forecast”). But it seems like the graph doesn’t update. It will load the “current” graph and just stay there until I restart MM.
                                lavolp3L 1 Reply Last reply
                                • lavolp3L
                                  lavolp3 Module Developer @ChickenBeard
                                  @ChickenBeard How did you disable the forecast? Via CSS or by commenting it out in the code?
                                    ChickenBeard @lavolp3
                                    @lavolp3 in ~/MagicMirror/config/config.js:
                                                           disabled:false,
                                                           position: 'bottom_center',  // This can be any of the regions.
        apiKey: 'xxxxx', // Dark Sky API key.
        // Only required if geolocation doesn't work:
        latitude:   xxxx,
        longitude: xxxx,
        ***enablePrecipitationGraph: true,***
        ***showForecast:false,***
        precipitationGraphWidth: 325,
        showWind: false,
        showSunriseSunset: false,
        ***alwaysShowPrecipitationGraph:true,***
                                    • lavolp3L
                                      @ChickenBeard I can’t see why it wouldn’t update. showForecast only determines if the forecast div is added to the DOM. I have currently no idea.
                                      Any error messages in the console?
                                      Maybe try
                                      debug: true
                                      in the config?
                                        @lavolp3 Will do! Which log does it write to?
                                        • lavolp3L
                                          @ChickenBeard usually this gives extended output to the server-side console in case of node_helper.js or to the browser console in case of the MMM-forecast-io.js.
                                          • lavolp3L
                                            For anyone interested:
                                            I have played around with this module quite intensively, implemented the chartjs library and did a few other tweaks and it looks like this now on my mirror.
                                            https://imgur.com/ZqJBGLp
                                            https://imgur.com/JmxnJ3p
                                            Most important changes:
                                            • the graph now shows several things:
                                              – cloud cover in the background
                                              – day and night cycle through different colors
                                              – rain amount in the foreground
                                            • temperature bars are colored according to temperature scale (currently only °C)
                                            • rain amount instead of rain percentage for daily forecast
                                            Anyone interested can try out my fork
                                            https://github.com/lavolp3/MMM-forecast-io
                                            If you install it, don’t forget to do a npm install in the module folder after cloning the module. The Readme has not yet been brought up to date.
                                            • 6 / 7
