    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 245.0k Views 38 Watching
      12wsx
      what is the problem with my module? the problem is on monitor connected to raspberry pi Zero (using midori browser) where MagicMirror is installed.
      My config:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	address: "::", // Address to listen on, can be:
      	port: 8080,
      	ipWhitelist: [], // Set [] to allow all IP addresses
      	language: "pl",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "clock",
      			position: "top_left"
      						symbol: "calendar-check-o ",
      						url: "https://calendar.google.com/xxxxxxxx"
      			module: "MMM-Solartemp",
      			position: "bottom_left",
      			header: "Solartemp",
      				baseURL: "http://xxxxxxxxxx",
      				key: "xxxxxxxxx",
      				group: "xxxxxx",
          			module: 'MMM-Remote-Control'
          			// , position: 'bottom_left'
      				module: 'MMM-forecast-io',
          				position: 'top_right',  // This can be any of the regions.
            				apiKey: 'xxxxxxx', // Dark Sky API key.
            				maxDaysForecast: 5,
      				forecastTableFontSize: 'small',
      				// Only required if geolocation doesn't work:
            				latitude:  xx.xxxx,
            				longitude: xx.xxxx
      alt text
      idoodlerI 1 Reply Last reply
      • idoodlerI
        idoodler Module Developer @12wsx
        @12wsx Are you using some custom CSS?
          12wsx
          no i don’t use custom css. But one thing- when I connect to magic mirror from my
          computer (win7 /firefox) everything is ok.
          • idoodlerI
            @12wsx Did you try using Chromium as a browser? Midori may have a hard time rendering the page.
            • H
              henryluyu
              Hi this is this module in my config.js.
              I simply put the “MMM-forecast-io-master” folder in /modules/default, I have also put my actual api key, latitude and longtitude values also in MMM-forecast-io.js. But no weather is showing, other modules working fine. Can anyone help please?
                                         apiKey: 'MYAPIKEY',
                                         latitude:   53.4839,
                                         longitude:  -2.2446
              Mykle1M 1 Reply Last reply
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @henryluyu
                @henryluyu said in MMM-forecast-io -- Localized up to the minute weather:
                1. Folder name should just be MMM-forecast-io
                2. Goes in modules folder, not the default folder
                That is not recommended. Putting those in your config.js will suffice.
                • F
                  Fifin404
                  Hi, is possible add “C” in all temperatures? Like 21 °C
                  and for wind add “km/h” like 8 km/h
                  C 1 Reply Last reply
                    code999
                    Hey all, anyone know how to get rid of the round bar in between the temps? 0_1574871951039_511494cd-8516-4507-93f2-b773a560930b-image.png
                    Thanks in advance.
                    morozgrafixM 1 Reply Last reply
                    • morozgrafixM
                      morozgrafix Moderator @code999
                      @code999 you can comment out this line forecastBar.appendChild(bar); but it will look kind of bad. Those bars are sort of a default look that you get from darksky/forecast UI.
                        code999 @morozgrafix
                        @morozgrafix what file do I edit? I can not find that line to comment it out. Thanks.
                        morozgrafixM lavolp3L 2 Replies Last reply
                        • morozgrafixM
                          @code999 it’s line 397 in MMM-fotecast-io.js https://github.com/dmcinnes/MMM-forecast-io/blob/77075e1c9011336f044d35f1c964fc93789a4201/MMM-forecast-io.js#L397
                          • lavolp3L
                            lavolp3 Module Developer @code999
                            @code999 it’s in the MMM-forecast-io.js file.
                            You can either try to comment out (//) or delete line 397
                            (only the bar)
                            or line 402
                            forecastBarWrapper.appendChild(forecastBar);
                            (with temps)
                            But why are you trying to delete it? It really doesn’t make sense to me and will look kind of ugly I guess.
                            How to troubleshoot modules
                            MMM-soccer v2, MMM-AVStock
                              code999 @lavolp3
                              @lavolp3 @morozgrafix Thank you both. I like an even look and the bar IMO is unless. when there is a large difference in temp it looks ridiculous. I might add something between numbers to give it some space and cleaner look. I did it mainly for space. I have it on the right side with my calendar taking up most of the screen. Anyway thanks again.
                                code999 @Fifin404
                                @Fifin404 I would like this also. Did you get it to show?
                                F lavolp3L 2 Replies Last reply
                                • F
                                  Fifin404 @code999
                                  @code999 NO, I use another module
                                  • lavolp3L
                                    @code999 @Fifin404
                                    You can add the “C” by putting this into your custom.css
                                    .MMM-forecast-io .bright:after {
                                      content: "C";
                                    That adds a “C” after the content of every element with the class “bright”. Luckily the temperature seems to be the only one.
                                    For the km/h, you would need to change the code of the main .js file, because wind is apparently calculated in m/s and you have to add the conversion factor 3.6 to convert to km/h.
                                    It’s possible of course but you should then consider forking the whole module and/or create a PR for that.
                                      ChickenBeard
                                      Is it possible to have the precipitation graph ONLY? I enabled it (and disabled the general “Forecast”). But it seems like the graph doesn’t update. It will load the “current” graph and just stay there until I restart MM.
                                      lavolp3L 1 Reply Last reply
                                      • lavolp3L
                                        lavolp3 Module Developer @ChickenBeard
                                        @ChickenBeard How did you disable the forecast? Via CSS or by commenting it out in the code?
                                          ChickenBeard @lavolp3
                                          @lavolp3 in ~/MagicMirror/config/config.js:
        disabled:false,
        position: 'bottom_center',  // This can be any of the regions.
        apiKey: 'xxxxx', // Dark Sky API key.
        latitude:   xxxx,
        longitude: xxxx,
        ***enablePrecipitationGraph: true,***
        ***showForecast:false,***
        precipitationGraphWidth: 325,
        showWind: false,
        showSunriseSunset: false,
        ***alwaysShowPrecipitationGraph:true,***
                                          • lavolp3L
                                            @ChickenBeard I can’t see why it wouldn’t update. showForecast only determines if the forecast div is added to the DOM. I have currently no idea.
                                            Any error messages in the console?
                                            Maybe try
                                            debug: true
                                            in the config?
                                            • 6 / 7
