    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 242.4k Views 38 Watching
    • morozgrafixM Offline
      morozgrafix Moderator @code999
      @code999 you can comment out this line forecastBar.appendChild(bar); but it will look kind of bad. Those bars are sort of a default look that you get from darksky/forecast UI.
        code999 @morozgrafix
        @morozgrafix what file do I edit? I can not find that line to comment it out. Thanks.
        morozgrafixM lavolp3L 2 Replies Last reply Reply Quote 0
          @code999 it’s line 397 in MMM-fotecast-io.js https://github.com/dmcinnes/MMM-forecast-io/blob/77075e1c9011336f044d35f1c964fc93789a4201/MMM-forecast-io.js#L397
          • lavolp3L Offline
            lavolp3 Module Developer @code999
            @code999 it’s in the MMM-forecast-io.js file.
            You can either try to comment out (//) or delete line 397
            (only the bar)
            or line 402
            forecastBarWrapper.appendChild(forecastBar);
            (with temps)
            But why are you trying to delete it? It really doesn’t make sense to me and will look kind of ugly I guess.
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
              code999 @lavolp3
              @lavolp3 @morozgrafix Thank you both. I like an even look and the bar IMO is unless. when there is a large difference in temp it looks ridiculous. I might add something between numbers to give it some space and cleaner look. I did it mainly for space. I have it on the right side with my calendar taking up most of the screen. Anyway thanks again.
                code999 @Fifin404
                @Fifin404 I would like this also. Did you get it to show?
                F lavolp3L 2 Replies Last reply Reply Quote 0
                • F Offline
                  Fifin404 @code999
                  @code999 NO, I use another module
                  • lavolp3L Offline
                    @code999 @Fifin404
                    You can add the “C” by putting this into your custom.css
                    .MMM-forecast-io .bright:after {
                      content: "C";
                    That adds a “C” after the content of every element with the class “bright”. Luckily the temperature seems to be the only one.
                    For the km/h, you would need to change the code of the main .js file, because wind is apparently calculated in m/s and you have to add the conversion factor 3.6 to convert to km/h.
                    It’s possible of course but you should then consider forking the whole module and/or create a PR for that.
                      ChickenBeard
                      Is it possible to have the precipitation graph ONLY? I enabled it (and disabled the general “Forecast”). But it seems like the graph doesn’t update. It will load the “current” graph and just stay there until I restart MM.
                      • lavolp3L Offline
                        lavolp3 Module Developer @ChickenBeard
                        @ChickenBeard How did you disable the forecast? Via CSS or by commenting it out in the code?
                          ChickenBeard @lavolp3
                          @lavolp3 in ~/MagicMirror/config/config.js:
                          module: 'MMM-forecast-io',
                                                 disabled:false,
                                                 position: 'bottom_center',  // This can be any of the regions.
                                                         apiKey: 'xxxxx', // Dark Sky API key.
                                                         // Only required if geolocation doesn't work:
                                                         latitude:   xxxx,
                                                         longitude: xxxx,
                                                         ***enablePrecipitationGraph: true,***
                                                         ***showForecast:false,***
                                                         precipitationGraphWidth: 325,
                                                         showWind: false,
                                                         showSunriseSunset: false,
                                                         ***alwaysShowPrecipitationGraph:true,***
                          • lavolp3L Offline
                            @ChickenBeard I can’t see why it wouldn’t update. showForecast only determines if the forecast div is added to the DOM. I have currently no idea.
                            Any error messages in the console?
                            Maybe try
                            debug: true
                            in the config?
                              @lavolp3 Will do! Which log does it write to?
                              • lavolp3L Offline
                                @ChickenBeard usually this gives extended output to the server-side console in case of node_helper.js or to the browser console in case of the MMM-forecast-io.js.
                                • lavolp3L Offline
                                  For anyone interested:
                                  I have played around with this module quite intensively, implemented the chartjs library and did a few other tweaks and it looks like this now on my mirror.
                                  https://imgur.com/ZqJBGLp
                                  https://imgur.com/JmxnJ3p
                                  Most important changes:
                                  • the graph now shows several things:
                                    – cloud cover in the background
                                    – day and night cycle through different colors
                                    – rain amount in the foreground
                                  • temperature bars are colored according to temperature scale (currently only °C)
                                  • rain amount instead of rain percentage for daily forecast
                                  Anyone interested can try out my fork
                                  https://github.com/lavolp3/MMM-forecast-io
                                  If you install it, don’t forget to do a npm install in the module folder after cloning the module. The Readme has not yet been brought up to date.
                                  • 7 / 7
