    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 245.0k Views 38 Watching
      code999 @lavolp3
      @lavolp3 @morozgrafix Thank you both. I like an even look and the bar IMO is unless. when there is a large difference in temp it looks ridiculous. I might add something between numbers to give it some space and cleaner look. I did it mainly for space. I have it on the right side with my calendar taking up most of the screen. Anyway thanks again.
        code999 @Fifin404
        @Fifin404 I would like this also. Did you get it to show?
        F lavolp3L 2 Replies Last reply
        • F
          Fifin404 @code999
          @code999 NO, I use another module
          • lavolp3L
            lavolp3 Module Developer @code999
            @code999 @Fifin404
            You can add the “C” by putting this into your custom.css
            .MMM-forecast-io .bright:after {
              content: "C";
            That adds a “C” after the content of every element with the class “bright”. Luckily the temperature seems to be the only one.
            For the km/h, you would need to change the code of the main .js file, because wind is apparently calculated in m/s and you have to add the conversion factor 3.6 to convert to km/h.
            It’s possible of course but you should then consider forking the whole module and/or create a PR for that.
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
              ChickenBeard
              Is it possible to have the precipitation graph ONLY? I enabled it (and disabled the general “Forecast”). But it seems like the graph doesn’t update. It will load the “current” graph and just stay there until I restart MM.
              lavolp3L 1 Reply Last reply
              • lavolp3L
                lavolp3 Module Developer @ChickenBeard
                @ChickenBeard How did you disable the forecast? Via CSS or by commenting it out in the code?
                C 1 Reply Last reply
                  ChickenBeard @lavolp3
                  @lavolp3 in ~/MagicMirror/config/config.js:
                  module: 'MMM-forecast-io',
                                         disabled:false,
                                         position: 'bottom_center',  // This can be any of the regions.
                                                 apiKey: 'xxxxx', // Dark Sky API key.
                                                 // Only required if geolocation doesn't work:
                                                 latitude:   xxxx,
                                                 longitude: xxxx,
                                                 ***enablePrecipitationGraph: true,***
                                                 ***showForecast:false,***
                                                 precipitationGraphWidth: 325,
                                                 showWind: false,
                                                 showSunriseSunset: false,
                                                 ***alwaysShowPrecipitationGraph:true,***
                  • lavolp3L
                    @ChickenBeard I can’t see why it wouldn’t update. showForecast only determines if the forecast div is added to the DOM. I have currently no idea.
                    Any error messages in the console?
                    Maybe try
                    debug: true
                    in the config?
                      @lavolp3 Will do! Which log does it write to?
                      • lavolp3L
                        @ChickenBeard usually this gives extended output to the server-side console in case of node_helper.js or to the browser console in case of the MMM-forecast-io.js.
                        • lavolp3L
                          For anyone interested:
                          I have played around with this module quite intensively, implemented the chartjs library and did a few other tweaks and it looks like this now on my mirror.
                          https://imgur.com/ZqJBGLp
                          https://imgur.com/JmxnJ3p
                          Most important changes:
                          • the graph now shows several things:
                            – cloud cover in the background
                            – day and night cycle through different colors
                            – rain amount in the foreground
                          • temperature bars are colored according to temperature scale (currently only °C)
                          • rain amount instead of rain percentage for daily forecast
                          Anyone interested can try out my fork
                          https://github.com/lavolp3/MMM-forecast-io
                          If you install it, don’t forget to do a npm install in the module folder after cloning the module. The Readme has not yet been brought up to date.
                          • 7 / 7
