    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 245.0k Views 38 Watching
    • F
      Fifin404
      Hi, is possible add “C” in all temperatures? Like 21 °C
      and for wind add “km/h” like 8 km/h
      C 1 Reply Last reply
        code999
        Hey all, anyone know how to get rid of the round bar in between the temps? 0_1574871951039_511494cd-8516-4507-93f2-b773a560930b-image.png
        Thanks in advance.
        morozgrafixM 1 Reply Last reply
        • morozgrafixM
          morozgrafix Moderator @code999
          @code999 you can comment out this line forecastBar.appendChild(bar); but it will look kind of bad. Those bars are sort of a default look that you get from darksky/forecast UI.
            code999 @morozgrafix
            @morozgrafix what file do I edit? I can not find that line to comment it out. Thanks.
            morozgrafixM lavolp3L 2 Replies Last reply
            • morozgrafixM
              @code999 it’s line 397 in MMM-fotecast-io.js https://github.com/dmcinnes/MMM-forecast-io/blob/77075e1c9011336f044d35f1c964fc93789a4201/MMM-forecast-io.js#L397
              • lavolp3L
                lavolp3 Module Developer @code999
                @code999 it’s in the MMM-forecast-io.js file.
                You can either try to comment out (//) or delete line 397
                (only the bar)
                or line 402
                forecastBarWrapper.appendChild(forecastBar);
                (with temps)
                But why are you trying to delete it? It really doesn’t make sense to me and will look kind of ugly I guess.
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                  code999 @lavolp3
                  @lavolp3 @morozgrafix Thank you both. I like an even look and the bar IMO is unless. when there is a large difference in temp it looks ridiculous. I might add something between numbers to give it some space and cleaner look. I did it mainly for space. I have it on the right side with my calendar taking up most of the screen. Anyway thanks again.
                    code999 @Fifin404
                    @Fifin404 I would like this also. Did you get it to show?
                    F lavolp3L 2 Replies Last reply
                    • F
                      Fifin404 @code999
                      @code999 NO, I use another module
                      • lavolp3L
                        @code999 @Fifin404
                        You can add the “C” by putting this into your custom.css
                        .MMM-forecast-io .bright:after {
                          content: "C";
                        That adds a “C” after the content of every element with the class “bright”. Luckily the temperature seems to be the only one.
                        For the km/h, you would need to change the code of the main .js file, because wind is apparently calculated in m/s and you have to add the conversion factor 3.6 to convert to km/h.
                        It’s possible of course but you should then consider forking the whole module and/or create a PR for that.
                          ChickenBeard
                          Is it possible to have the precipitation graph ONLY? I enabled it (and disabled the general “Forecast”). But it seems like the graph doesn’t update. It will load the “current” graph and just stay there until I restart MM.
                          lavolp3L 1 Reply Last reply
                          • lavolp3L
                            lavolp3 Module Developer @ChickenBeard
                            @ChickenBeard How did you disable the forecast? Via CSS or by commenting it out in the code?
                              ChickenBeard @lavolp3
                              @lavolp3 in ~/MagicMirror/config/config.js:
                              module: 'MMM-forecast-io',
                                                     disabled:false,
                                                     position: 'bottom_center',  // This can be any of the regions.
                                                             apiKey: 'xxxxx', // Dark Sky API key.
                                                             // Only required if geolocation doesn't work:
                                                             latitude:   xxxx,
                                                             longitude: xxxx,
                                                             ***enablePrecipitationGraph: true,***
                                                             ***showForecast:false,***
                                                             precipitationGraphWidth: 325,
                                                             showWind: false,
                                                             showSunriseSunset: false,
                                                             ***alwaysShowPrecipitationGraph:true,***
                              • lavolp3L
                                @ChickenBeard I can’t see why it wouldn’t update. showForecast only determines if the forecast div is added to the DOM. I have currently no idea.
                                Any error messages in the console?
                                Maybe try
                                debug: true
                                in the config?
                                  @lavolp3 Will do! Which log does it write to?
                                  • lavolp3L
                                    @ChickenBeard usually this gives extended output to the server-side console in case of node_helper.js or to the browser console in case of the MMM-forecast-io.js.
                                    • lavolp3L
                                      For anyone interested:
                                      I have played around with this module quite intensively, implemented the chartjs library and did a few other tweaks and it looks like this now on my mirror.
                                      https://imgur.com/ZqJBGLp
                                      https://imgur.com/JmxnJ3p
                                      Most important changes:
                                      • the graph now shows several things:
                                        – cloud cover in the background
                                        – day and night cycle through different colors
                                        – rain amount in the foreground
                                      • temperature bars are colored according to temperature scale (currently only °C)
                                      • rain amount instead of rain percentage for daily forecast
                                      Anyone interested can try out my fork
                                      https://github.com/lavolp3/MMM-forecast-io
                                      If you install it, don’t forget to do a npm install in the module folder after cloning the module. The Readme has not yet been brought up to date.
                                      • 6 / 7
