Weatherforecast problem.
5 Posts 3 Posters 2.0k Views 2 Watching
  • N Offline
    Nico Biester
    Hello. I have a problem with my wheaterforecaster module as you can see in the title. Since I filled the locationID and the API key In the config.js datafile my MagicMirror dont start correctly and just say “Please create a config file.” Here is my config.js file. The XXX are just placeholder for personal informations.
    		module: "weatherforecast",
    		config:
    			locationID: "", Location ID from https://openweathermap.org/city/2946447
    			appid: "xxx" //openweathermap.org API key.
      SoleLo
      @Nico-Biester when you put your location ID the text after is commented out or removed?
        AxLed Module Developer
        @Nico-Biester
        Hi Nico,
        try this:
        			header: "Weather Forecast",
        				locationID: "2946447",  //ID from http://www.openweathermap.org/help/city_list.txt
        AxLED
        N 1 Reply Last reply Jul 4, 2018, 2:26 PM Reply Quote 0
        • N Offline
          Nico Biester @AxLed
          @axled Thanks for your help. It worked. :D
            @Nico-Biester
            Can you mark this Thread as solved?
            AxLed
