    Weatherforecast problem.
    5 Posts 3 Posters 2.1k Views 2 Watching
    • N Offline
      Nico Biester
      Hello. I have a problem with my wheaterforecaster module as you can see in the title. Since I filled the locationID and the API key In the config.js datafile my MagicMirror dont start correctly and just say “Please create a config file.” Here is my config.js file. The XXX are just placeholder for personal informations.
      		module: "weatherforecast",
      		config:
      			locationID: "", Location ID from https://openweathermap.org/city/2946447
      			appid: "xxx" //openweathermap.org API key.
        SoleLo
        @Nico-Biester when you put your location ID the text after is commented out or removed?
          AxLed Module Developer
          @Nico-Biester
          Hi Nico,
          try this:
          			header: "Weather Forecast",
          				locationID: "2946447",  //ID from http://www.openweathermap.org/help/city_list.txt
          AxLED
          • N Offline
            Nico Biester @AxLed
            @axled Thanks for your help. It worked. :D
              @Nico-Biester
              Can you mark this Thread as solved?
              AxLed
