    pm2 logs - UnhandledPromiseRejectionWarning
    7 Posts 3 Posters 3.0k Views 1 Watching
    • O Offline
      ooskay
      using v.2.4.1
      in the pm2 logs i see below error message with each loading. Any suggestion?
      1|mm | (node:2597) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): TypeError: Cannot read property ‘refs’ of undefined
      1|mm | (node:2597) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      1|mm | (node:2597) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): TypeError: Cannot read property ‘refs’ of undefined
      1|mm | (node:2597) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3): TypeError: Cannot read property ‘refs’ of undefined
      SnilleS 1 Reply Last reply Reply Quote 0
      • SnilleS Offline
        Snille Module Developer @ooskay
        @ooskay Hi! I get this error to. What modules do you run in your mirror? I think it may be one of my modules causing the problem.
        This is my list:
        calendar_monthly
        mm-hide-all
        MMM-CalendarExt
        MMM-Chart
        MMM-cryptocurrency
        MMM-Globe
        MMM-iFrameReload
        MMM-JSONStatusChecker
        MMM-Memo
        MMM-Modulebar
        MMM-ModuleScheduler
        MMM-MotionEye
        MMM-MyCalendar
        MMM-MyCommute
        MMM-newsfeedtouch
        MMM-plex-recently-added
        MMM-Profilepicture
        MMM-ProfileSwitcher
        MMM-Remote-Control
        MMM-Sonos
        mmm-suncalc
        MMM-TextClock
        MMM-Tools
        MMM-TouchNavigation
        MMM-WunderGround
        What do you have?
        If you cant find it, make it and share it!
        Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
        • O Offline
          ooskay
          hi,
          try disable remote control to see result. i’m away from my setup.
          • bheplerB Offline
            bhepler Module Developer @ooskay
            @ooskay - Please post your config.js file here and we’ll take a look at it. When you do, be sure to use the forum markdown features to help us read your file and be sure to remove any API keys from your file to keep them private. Here is a link explaining the markdown features.
            • O Offline
              ooskay
              • O Offline
                ooskay
                /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
                var config =
                	address: "0.0.0.0",
                	electronOptions: {
                	ipWhitelist: [
                		"127.0.0.1",
                		"0.0.0.0",
                		"::1",
                		"192.168.1.0/24"
                	language: "tr",
                			module: "alert",
                			module: "MMM-Remote-Control",
                			module: "updatenotification",
                			position: "top_bar",
                			module: "MMM-EARTH",
                			header: "",
                			position: "upper_third",
                				rotateInterval: 15000,
                				MonthsArray: {
                					Jan: "01",
                					Feb: "02",
                					Mar: "03",
                					Apr: "04",
                					May: "05",
                					Jun: "06",
                					Jul: "07",
                					Aug: "08",
                					Sep: "09",
                					Oct: "10",
                					Nov: "11",
                					Dec: "12"
                			module: "clock",
                			header: "Resmi Tatiller",
                						symbol: "calendar-check-o ",
                						url: "http://88.248.2.178/onur/calendar.php"
                				titleReplace: {
                					"De verjaardag van ": "",
                					"'s birthday": ""
                				excludedEvents: [
                			module: "compliments",
                			position: "lower_third",
                				compliments: {
                					anytime: [
                						"Merhaba!",
                						"Bugün Harika Gözüküyorsunuz :) "
                					morning: [
                						"Günaydın!",
                						"İyi bir gün geçirmenizi dilerim!",
                						"Güzel bir gün geçirmeniz dileğiyle!"
                					afternoon: [
                						"Merhaba",
                						"Gününüz nasıl geçiyor?",
                						"Gününüz umarım iyi geçiyordur!"
                					evening: [
                						"İyi akşamlar!",
                						"Umarım gününüz iyi geçmiştir!",
                						"İyi geceler!"
                			module: "MMM-Cursor",
                			module: "currentweather",
                				locationID: "323777",
                				appid: "d3a9feef45f79bd25729df85b125194d",
                				iconTable: {
                					"01d": "wi-day-sunny",
                					"02d": "wi-day-cloudy",
                					"03d": "wi-cloudy",
                					"04d": "wi-cloudy-windy",
                					"09d": "wi-showers",
                					"10d": "wi-rain",
                					"11d": "wi-thunderstorm",
                					"13d": "wi-snow",
                					"50d": "wi-fog",
                					"01n": "wi-night-clear",
                					"02n": "wi-night-cloudy",
                					"03n": "wi-night-cloudy",
                					"04n": "wi-night-cloudy",
                					"09n": "wi-night-showers",
                					"10n": "wi-night-rain",
                					"11n": "wi-night-thunderstorm",
                					"13n": "wi-night-snow",
                					"50n": "wi-night-alt-cloudy-windy"
                			module: "MMM-JsonTable",
                			position: "botto
                • O Offline
                  ooskay
                  Problem was in MMM remote control module. Error message disappeared when i disabled it.
