pm2 logs - UnhandledPromiseRejectionWarning
7 Posts 3 Posters 2.3k Views 1 Watching
  • O Offline
    ooskay
    using v.2.4.1
    in the pm2 logs i see below error message with each loading. Any suggestion?
    1|mm | (node:2597) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): TypeError: Cannot read property ‘refs’ of undefined
    1|mm | (node:2597) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    1|mm | (node:2597) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): TypeError: Cannot read property ‘refs’ of undefined
    1|mm | (node:2597) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3): TypeError: Cannot read property ‘refs’ of undefined
    S 1 Reply Last reply Aug 1, 2018, 5:57 PM Reply Quote 0
      Snille Module Developer @ooskay
      @ooskay Hi! I get this error to. What modules do you run in your mirror? I think it may be one of my modules causing the problem.
      This is my list:
      calendar_monthly
      mm-hide-all
      MMM-CalendarExt
      MMM-Chart
      MMM-cryptocurrency
      MMM-Globe
      MMM-iFrameReload
      MMM-JSONStatusChecker
      MMM-Memo
      MMM-Modulebar
      MMM-ModuleScheduler
      MMM-MotionEye
      MMM-MyCalendar
      MMM-MyCommute
      MMM-newsfeedtouch
      MMM-plex-recently-added
      MMM-Profilepicture
      MMM-ProfileSwitcher
      MMM-Remote-Control
      MMM-Sonos
      mmm-suncalc
      MMM-TextClock
      MMM-Tools
      MMM-TouchNavigation
      MMM-WunderGround
      What do you have?
      If you cant find it, make it and share it!
      Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
      • O Offline
        ooskay
        hi,
        try disable remote control to see result. i’m away from my setup.
        B 1 Reply Last reply Aug 2, 2018, 1:11 AM Reply Quote 0
          bhepler Module Developer @ooskay
          @ooskay - Please post your config.js file here and we’ll take a look at it. When you do, be sure to use the forum markdown features to help us read your file and be sure to remove any API keys from your file to keep them private. Here is a link explaining the markdown features.
          • O Offline
            ooskay
            • O Offline
              ooskay
              /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
              var config =
              	address: "0.0.0.0",
              	electronOptions: {
              	ipWhitelist: [
              		"127.0.0.1",
              		"0.0.0.0",
              		"::1",
              		"192.168.1.0/24"
              	language: "tr",
              			module: "alert",
              			module: "MMM-Remote-Control",
              			module: "updatenotification",
              			position: "top_bar",
              			module: "MMM-EARTH",
              			header: "",
              			position: "upper_third",
              				rotateInterval: 15000,
              				MonthsArray: {
              					Jan: "01",
              					Feb: "02",
              					Mar: "03",
              					Apr: "04",
              					May: "05",
              					Jun: "06",
              					Jul: "07",
              					Aug: "08",
              					Sep: "09",
              					Oct: "10",
              					Nov: "11",
              					Dec: "12"
              			module: "clock",
              			header: "Resmi Tatiller",
              						symbol: "calendar-check-o ",
              						url: "http://88.248.2.178/onur/calendar.php"
              				titleReplace: {
              					"De verjaardag van ": "",
              					"'s birthday": ""
              				excludedEvents: [
              			module: "compliments",
              			position: "lower_third",
              				compliments: {
              					anytime: [
              						"Merhaba!",
              						"Bugün Harika Gözüküyorsunuz :) "
              					morning: [
              						"Günaydın!",
              						"İyi bir gün geçirmenizi dilerim!",
              						"Güzel bir gün geçirmeniz dileğiyle!"
              					afternoon: [
              						"Merhaba",
              						"Gününüz nasıl geçiyor?",
              						"Gününüz umarım iyi geçiyordur!"
              					evening: [
              						"İyi akşamlar!",
              						"Umarım gününüz iyi geçmiştir!",
              						"İyi geceler!"
              			module: "MMM-Cursor",
              			module: "currentweather",
              				locationID: "323777",
              				appid: "d3a9feef45f79bd25729df85b125194d",
              				iconTable: {
              					"01d": "wi-day-sunny",
              					"02d": "wi-day-cloudy",
              					"03d": "wi-cloudy",
              					"04d": "wi-cloudy-windy",
              					"09d": "wi-showers",
              					"10d": "wi-rain",
              					"11d": "wi-thunderstorm",
              					"13d": "wi-snow",
              					"50d": "wi-fog",
              					"01n": "wi-night-clear",
              					"02n": "wi-night-cloudy",
              					"03n": "wi-night-cloudy",
              					"04n": "wi-night-cloudy",
              					"09n": "wi-night-showers",
              					"10n": "wi-night-rain",
              					"11n": "wi-night-thunderstorm",
              					"13n": "wi-night-snow",
              					"50n": "wi-night-alt-cloudy-windy"
              			module: "MMM-JsonTable",
              			position: "botto
              • O Offline
                ooskay
                Problem was in MMM remote control module. Error message disappeared when i disabled it.
