    MMM-SORT
    10 Posts 3 Posters 3.6k Views 2 Watching
      Mykle1 Project Sponsor Module Developer @scott5532
      @scott5532 said in MMM-SORT:
      Please can anyone help.
      Your config entry above is not complete. I completed it and tested it. The module fires right up. You can see both the static and rotating options running in my screenshot.
      Your complete config entry should look like this:
      disabled: false,
      	module: "MMM-SORT",
      	position: "bottom_left",
      		apiKey: "YOUR API KEY GOES HERE",
      		lat: "54.992562",           // your latitude
      		lon: "-1.451674",          // your longitude
      		mode: "rotating",             // static or rotating
      		LowText: "Low Tide",             // Low tide text. Whatever you want or nothing "",
      		HighText: "High Tide",           // High tide text. Whatever you want or nothing "",
      		height: "m",               // ft = feet, m = meters (When mode: is rotating)
      		useHeader: false,           // false if you don't want a header
      		header: "",                 // Change in config file. useHeader must be true
      		maxWidth: "300px",
      		animationSpeed: 3000,       // fade speed
      		rotateInterval: 20 * 1000,  // seconds (When mode: is rotating)
      I also see that you made changes to the MMM-SORT.js file. That’s not recommended unless you absolutely know what you want to accomplish there.
      I suggest you delete what you have and re-install the module from the repo. Use the config entry that I posted above and I’m sure you will be successful, unless you’ve made other changes that I am not aware of.
      https://github.com/mykle1/MMM-SORT
      P.S. You should keep your API keys private
      • scott5532S Offline
        scott5532
        Hello Mykle1,
        Thanks for you help and support. It is very much appreciated.
        I am a Hazardous Area Response Team Paramedic in the north of England and our mirror is going on the wall in the crew room as a information screen. The screen is a 60" monitor we liberated from the command room during a recent refurbishment. will send a photo when its up, but this is how it will look. (excuse sniping tool in the middle).
        Thanks again,
        Andy Scott
        USAR paramedic, NEAS HART
        Mykle1M 2 Replies Last reply Reply Quote 1
          Hello Andy, and well met.
          I am honored that you and your crew found my tide module worthy enough to be included on your information screen. I would like to thank you for the work that you do. My daughter works in Emergency as a PA and I am a retired New York City Police Officer. I’ve worked with many different response teams so I can appreciate what you do. Please extend my gratitude to your team and be safe.
          Highest regards,
          Mykle
          bheplerB 1 Reply Last reply Reply Quote 3
            @scott5532
            As per your question via message
            I’m going to update the repo with some padding in the css file. You should copy and paste what you like into the custom.css file and make your changes there.
            Here is a new picture with a bit of padding between lines. You can adjust to your liking.
              Attention: @scott5532
              You can now do a git pull in the MMM-SORT directory. to acquire the new css file that contains the fix for the issue you were having. Namely, the space between lines (divs). Kindly transfer the css rules to your custom.css file and make your changes there.
              Peace
                scott5532
                @mykle1
                All done and fixed to the wall in the office. Thanks again for all your help, much appreciated.
                Best wishes
                Andy Scott (NEAS HART)
                  @scott5532
                  That is simply fantastic! Again, I am honored. :-)
                  • bheplerB Offline
                    bhepler Module Developer @Mykle1
                    @mykle1 said in MMM-SORT:
                    No kidding. Interesting.
                    @scott5532 said in the same #$?@!! thread
                    Now that sounds like a worthy purpose. Let’s get you fixed up.
                    Honestly, I would ditch either the analog clock or the digital one. You’re being redundant in your information. Additionally, I would add a header to the SORT module so that it’s obvious what information is being conveyed in that section of the display.
                      Mykle1 Project Sponsor Module Developer @bhepler
                      @bhepler said in MMM-SORT:
                      How so? 'Tis true. :-)
