    Can you help me about this error
    29 Posts 4 Posters 11.3k Views 4 Watching
    • justjim1220J
      justjim1220 Module Developer @Mykle1
      @mykle1
      LMAO!
      I was posting my reply when yours popped up! :winking_face:
      Jim Hallock - 1995
      • justjim1220J
        justjim1220 Module Developer @Fonfon
        @fonfon
        Jim Hallock - 1995
        F 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Fonfon
          @fonfon
          I’d like to see any errors from your terminal and/or your console
          • F
            Fonfon @justjim1220
            @justjim1220
            info it worked if it ends with ok
            1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
            2 info using npm@3.10.10
            3 info using node@v6.13.1
            4 verbose stack Error: ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/package.json’
            4 verbose stack at Error (native)
            5 verbose cwd /home/pi/MagicMirror/modules
            6 error Linux 4.9.59-v7+
            7 error argv “/usr/bin/node” “/usr/bin/npm” “start”
            8 error node v6.13.1
            9 error npm v3.10.10
            10 error path /home/pi/MagicMirror/modules/package.json
            11 error code ENOENT
            12 error errno -2
            13 error syscall open
            14 error enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/package.json’
            15 error enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/package.json’
            15 error enoent This is most likely not a problem with npm itself
            15 error enoent and is related to npm not being able to find a file.
            16 verbose exit [ -2, true ]
            this is my npm-debug.log
            i dont understand it i think its a problem with package .js
            i try to start with npm start -dev for a error log
            where is the error log in wich folder?
            thanks for your help
            Mykle1M 1 Reply Last reply
            • F
              Fonfon @Mykle1
              This is after only 15 min of MM running
              ? 2 Replies Last reply
                A Former User @Fonfon
                @fonfon
                One of your modules is using promise pattern but not handling rejection. Usually this is caused by missing some exception handling in module.
                I cannot figure out which module is causing that message. You can find which module has problem by disabling or removing module from config.js one-by-one.
                Maybe your suspicious module might have SOMETHING.hash in its codes. the error will be caused object SOMETHING is really null. so, when you find which module has the error, tell the module developer the symptom. (S)he will fix it.
                  @fonfon
                  And one more thing.
                  Most of those UnhandledPromiseRejectionWarning does not give harm to MM’s execution, the real problem is TypeError: Cannot read property 'hash' of null. You should find which module is causing this message.
                  • Mykle1M
                    @fonfon said in Can you help me about this error:
                    Start MM with npm start dev. This opens the Developers Tools window. Click “Console” tab at the top of the window. Here you will find any errors. It does not save as a log.
                    Follow Sean’s suggestion (and mine) that you determine which module is causing the issue. Then paste the errors from that module here.
                    • F
                      Fonfon @Mykle1
                      @mykle1 When i start with npm start dev: 0_1533511909992_2018-08-06-012648_1080x1920_scrot.jpg
                      Mykle1M ? 2 Replies Last reply
                      • Mykle1M
                        @fonfon
                        Do you get that error with just the default modules?
                        • F
                          Fonfon @Mykle1
                          @mykle1 yes with default modules
                          • Mykle1M
                            only with pir module its good
                            but after with wunderground or google maps traffic module i have a lot of error or other…
                            Above you said with pir module its good . . . .
                            So now I am confused. I think that perhaps we don’t understand each other. Run MM with ONLY the default modules. If you are having trouble that way then your problem lies with your installation of MM.
                              @fonfon
                              I think there is invalid ’timezone’ value in your config(whichever it is)
                              Have you set any value with ’Etc/gmt+1’?
                              • F
                                Fonfon @Guest
                                @sean yes in my config for clock module i have gmt +1
                                  @fonfon
                                  Use Etc/GMT+1 instead Etc/GMT+01.
                                  But, this modifying only can fix your front-end error of Moment Timezone has no data for..., not your UnhandledPromise... error in the background-server.
                                  You should remove modules one-by-one to figure out which module is causing that error.
                                    @fonfon
                                    And Could you tell us which modules are in your config.js?
                                    • F
                                      Fonfon
                                      OK guys i think i find my problems:
                                      You have included the Google Maps JavaScript API multiple times on this page.This may cause unexpected errors
                                      The google trafic module is the cause
                                      An idea to fix it ?
                                      thanks
                                      ? 1 Reply Last reply
                                        @fonfon
                                        First, I think you’d better ask the creator on Github.
                                        Second, Have you registered that module once?
                                        • F
                                          Fonfon
                                          ok when i started only MMM-GoogleMapsTraffic in dev mode:
                                          Dev say i start with 5 keys but in my config file i have only one !
                                          thanks
