    error loop
    11 Posts 3 Posters 4.2k Views 3 Watching
      A Former User
      Have you assigned proper position for that module in config.js?
        jchenaud
        @Sean
        thanks you have suppress the first error on screen-shot
        but my modul write something on screen and i don’t want that but its can be cool for debug
          A Former User @jchenaud
          @jchenaud
          If your module doesn’t need to possess area in MagicMirror (even your module would draw something on MM), you wouldn’t use .getDom(). That function should be called by MM.core when the refreshing screen is needed. but your .getDom() will not work properly because there is no position to be drawn on.
          So you should assign a position to use .getDom().
          (Of course, there is some trick without .getDom() and position to draw something on MM)
            jchenaud @Guest
            @sean
            thk for explain. i will try something different to get.getDom().
            have you an idea for appendChild error ?
              @jchenaud I think that is also caused by unproper using of .getDom()
              Better practice is;
              1. use .getDom() with proper position
              2. or, not using .getDom().
              • You can start to manipulate your DOM when DOM_OBJECTS_CREATED notification from MM Core.
                like these;
              notificationReceived: function(noti, payload, sender) {
                switch(noti) {
                  case 'DOM_OBJECTS_CREATED':
                    this.initMyDOM()
                    break
              initMyDOM: function() {
                var wrapper = document.createElement("div")
                wrapper.id = "myDOM"
                var container = document.body
                container.appendChild(wrapper)
               var timer = setInterval(()=>{
                var d = document.getElementById("myDOM")
                d.innerHTML = "This is rendered without getDom and position"
                }, 1000)
              This is not tested on real device, but you can catch the idea.
                jchenaud
                thk i will try :)
                  jchenaud
                  @Sean you are awesome !!!
                  my module almost work
                  just one problem i need to give a position in config. i think i have miss something
                  Module.register("MMM-keylogger",{
                  	defaults: {
                  		 updateInterval:  1500,
                  		Log.log(`notif : ${noti}`);
                  		switch(noti) {
                  		  case 'MODULE_DOM_CREATED':
                  			this.initMyDOM()
                  			break
                  		Log.log(`init DOM `);
                  			d.innerHTML =  this.dataFile
                  		Log.log(`key : ${d.innerHTML} , ${this.dataFile} `);
                  			if(d.innerHTML){
                  				switch(d.innerHTML) {
                  					case "Right":
                  					this.sendNotification("PAGE_INCREMENT");
                  						break;
                  					case "Left" :
                  					this.sendNotification("PAGE_DECREMENT");
                  						break;
                  					default:
                  					Log.log(`key : ${d.innerHTML} pressed but not assigned`);
                  				this.sendSocketNotification("Clear_key")
                  			}, 1500)
                  	start: function(){
                          console.log(this.name + " has started...!!!!!!");
                  		this.sendSocketNotification("START", this.config);
                  		if(notification === "KEY_P"){
                  			this.dataFile = payload;
                  			// this.updateDom();
                  if i don’t give position on config its don’t work ! if i have understand what you have say. this is suppose to work
                  other question : one of my other module have subitly stop to work and make same error but in this module in need position and update with Miror display. so my question is : this is possible this modification have impact on other module ?
                    @jchenaud
                    MODULE_DOM_CREATED is not so good time. Because, It would be emitted when Your DOM was created, but All of other DOMs are not rendered yet. DOM_OBJECTS_CREATED is better.
                    If you want to using position, use .getDom(). A usual way to use position is, in .getDom() to initialize your rendering and to prepare the framework to draw.
                    And you can choose one of drawing tricks.
                    1. getDom() shall take care of all the drawing. in .getDom() put all of your rendering framework and contents. and you can refresh your render by calling .updateDom()
                    2. getDom() shall draw only framework, Contents should be drawn by your another function with HTML DOM manipulation.
                    3. or getDom() just return empty wrapper, Then, all of your rendering and refreshing will be performed by yourself.
                    Which is better? case-by-case.
                    For the last question; I cannot figure out. :)
